1977 F-100 restoration project - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 08-22-2011, 10:12 AM
nlareau's Avatar
nlareau nlareau is offline
nlareau is starting off with a positive reputation.
Learn something new every day. I didn't know that. I think I did get lucky, but that's all it was: luck. Thanks.
  #32
Old 08-24-2011, 07:38 AM
nlareau's Avatar
Busy day yesterday
Got the front windshield installed yesterday. The guys at Georgia Auto Glass showed up on time and were $75 cheaper than I could have bought it myself.
Put the rear window in myself. The rope trick works great. If you don't have one of those special window-moulding-thingy tools, use a paint can opener. That worked really well.
Stuck the hood on. It is sitting 1/2" high, not sure why. Haven't tried to figure that out yet.
Stuck the fenders on.
Then the doors
Then I put in the seats. I was pretty happy with the LMC re-upholstery kit. Spent the rest of the day trying to get the bed wood to fit. Not a lot of success there. I was worn out by 6 PM, I'd been working by myself all day. Putting an F100 hood on by yourself is no fun at all.
Put the dash metalwork and pad back in.
Stuck a couple of pieces of door molding on and called it a day.
  #33
Old 08-24-2011, 08:36 AM
Grubbworm's Avatar
Grubbworm Grubbworm is offline
Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.
Awesome work, looks like it is coming along nicely. Did you take the front window/trim out yourself? How did you get the trim off?
  #34
Old 08-24-2011, 09:05 AM
nlareau's Avatar
Quote:
The front window was cracked and the molding on the front and back was dry rotting. Pulled the old chrome strips out with small screwdrivers and then we just cut the front half off of the molding with a razor and the windows popped right out.
The back window installation was easy. I'm glad I had pro's do the front. They said it was the single widest windshield they'd ever seen. Took them 90 minutes from start to finish.
  #35
Old 08-24-2011, 09:10 AM
Grubbworm's Avatar
My ex-son-in-law's brother does windows for a living in Cartersville. I am thinking of getting him to come over to the house and remove the front window trim. Later, when I have finished my work, I will call him back to replace the window. If you don't mind me asking...what was the price you paid?
  #36
Old 08-24-2011, 09:18 AM
nlareau's Avatar
$199.95 for the glass and installation. I already had the new molding. Just buying the glass from LMC would be $260. The other local estimates I got were all in the $275 range.
  #37
Old 08-25-2011, 10:32 PM
nutinbutford nutinbutford is offline
nutinbutford is starting off with a positive reputation.
nice build! I'm restoring the same truck....77 Short box Flareside.
would you happen to have any pics of the original parking brake connections in and around the equalizer? it would be a big help. I'm putting mine back to original condition without any offshore parts. It's taken me almost 6 years to get to this point.
  #38
Old 08-26-2011, 07:23 AM
nlareau's Avatar
Can't help you there, mine is messed up too. What I do know is that the picture in the LMCtruck catalog is wrong for the F100. To my knowledge there is no lever or spring, just the 'coupler' that connects the cable from the cab to the left and right wheel cables. Both of my wheel cables are completely frozen in the 'on' position, I've had to disconnect them to free the rear wheels.
  #39
Old 08-26-2011, 07:39 AM
rdweathers rdweathers is offline
rdweathers is starting off with a positive reputation.
Quote:
Originally Posted by kobaltblue View Post
Thats too cool...Orange peal is good with a little 800-1000 grit wet paper and alot of elbow grease!....Please tell me you didn't put the converter on the motor then put the tranny on, The pump wont be engaged and it will destroy the transmission!
That is what i thought also when i seen the torque converter on the motor.
  #40
Old 09-04-2011, 06:42 PM
nlareau's Avatar
Finally got tired of too small alternators and bad regulators. Followed the instructions I got here and did a 3G upgrade. Popped right in and worked like a charm. Electric fans pulling 40 amps and I'm still at 13 volts charging the battery.
$26 total. Wish I had done this two alternators ago.
  #41
Old 09-04-2011, 07:02 PM
ironman540 ironman540 is offline
ironman540 is starting off with a positive reputation.
fantastic to see one of these kings of the road getting put back together. have a 79 ford f150 4wd flareside sitting in pieces working to get it back together. good luck and keep posting progress
  #42
Old 09-04-2011, 07:07 PM
shadow_almanza shadow_almanza is offline
shadow_almanza is starting off with a positive reputation.
Which thread did you use for the 3g
  #43
Old 09-04-2011, 08:42 PM
nlareau's Avatar
Quote:
http://www.ford-trucks.com/forums/94...g-upgrade.html
Works great
  #44
Old 10-01-2011, 08:28 AM
nlareau's Avatar
Don't look too closely at the grille, it still needs to get cleaned up and painted.
Still need to get the turn signals working, pull the steering wheel and get the horn fixed, and I hate to say it, I've got to drop the transmission pan, pull the valve body and fix the kickdown lever. It won't go into 3rd and I'm pretty sure this KD lever isn't supposed to flop around like it does.
But we are starting to get close. After I clean it up more, I'll post some shots of the interior. It isn't anything special, though.
  #45
Old 10-01-2011, 03:09 PM
D24x4's Avatar
D24x4 D24x4 is offline
D24x4 is starting off with a positive reputation.
Looks great - good job! Did you get your wood bed worked out? If so, do you have any photos?
Mark
new to the site twistedfreak 1961 - 1966 F-100 & Larger F-Series Trucks 48 04-11-2016 03:14 PM
Brandon's highboy project. big-ugly Nebraska Chapter 134 03-04-2016 01:07 PM
New rad installed. longview1 6.4L Power Stroke Diesel 8 11-30-2013 11:19 PM
My junk-O-rific 59' blackedout 1957 - 1960 F100 & Larger F-Series Trucks 111 11-21-2013 03:50 PM
New tires longview1 6.4L Power Stroke Diesel 5 07-20-2011 09:12 PM
Tags
100, 1973, 1977, 1979, 1999, 77, f100, ford, hood, project, projects, restoration, series, truck, trucks, wwwuse
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
