Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 04-29-2011, 04:28 AM
Jax Rhapsody's Avatar
Jax Rhapsody Jax Rhapsody is offline
Garage is empty, add now
Jax Rhapsody is starting off with a positive reputation.
1st Gen Lightning
I've been looking for hors and can't find anything on the differences between them and regular F150's. Aside from the engine and transmission, I mean. I also can't find anything aftermarket regarding the suspension for 80-96 trucks. Does the lighting have a different TTB than regular trucks? And how are all these people dropping these trucks, when I can't find anything online or in magazines for full size TTBs for lowering trucks. I've only seen some for Rangers/Explorers. I've barelly found anything for 2wd pre-runners.
  #2 (permalink)
Old 04-30-2011, 12:17 PM
SideWinder4.9l's Avatar
SideWinder4.9l SideWinder4.9l is online now
1992 Ford F-150
SideWinder4.9l has a brilliant futureSideWinder4.9l has a brilliant futureSideWinder4.9l has a brilliant futureSideWinder4.9l has a brilliant futureSideWinder4.9l has a brilliant futureSideWinder4.9l has a brilliant futureSideWinder4.9l has a brilliant futureSideWinder4.9l has a brilliant futureSideWinder4.9l has a brilliant futureSideWinder4.9l has a brilliant futureSideWinder4.9l has a brilliant future
The only difference is:
351w in the F-150
4.10/4.11 rear gears
Sway bars front and back
Bucket seats
Other than that, they use the E4OD tranny, and everything else is basically the same....
You can get a lowering kit from Eibach, DJM, Belltech, etc....
Lowering shocks, tranny shift kit, and if you REALLY wanna drop $$$, www.Fastfordfiberglass.com sells fiberglass hoods, rollpans, front bumpers, fenders, cowls, and tailgates.....
__________________
Wesley
1992 F-150 Michelle-300I6 w/ 5 Speed
Hurst Short Throw Shifter/ Cold Air Intake
Owner of Renegade Auto & Heavy Truck Solutions, LLC
19.31 E/T @ 68.78mph
  #3 (permalink)
Old 05-01-2011, 05:57 AM
lew52's Avatar
lew52 lew52 is online now
lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.
If you can't find anything listed , i would call DJM or belltech , theres a few guys in the 87-96 forum that have lowered them , they should be able to help you , the suspension and springs on the lightnings are not the same as the standard 150s , i think the frame is thicker to , motor wise its a 351w with gt 40 heads and intake , they have a flat tappet cam instead of a roller and are SD.....Lew
  #4 (permalink)
Old 05-01-2011, 09:37 AM
86F150302's Avatar
86F150302 86F150302 is offline
1994 Ford F-150
86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.
Popwarhomie
Quote:
351w in the F-150
Bucket seats
Not exactly..
Click the image to open in full size.
OP: To lower a Lightning would be the same as an F150. Drop I beams in front and shackle and hanger in rear/flip kit. Just know that the Lightnings come from the factory lowered 1" in front(Springs) and 2.5" in back(leaf springs).
__________________
94 Lightning /FMS headers/No cats/Borla DIDO/Gen 2 exit/3" CAI/ Alpine CDA-105/200 amp alt/Kicker KS components/Sundown Audio SA-8s/ AQ1200D/Optima battery/Saginaw P.S. pump/Full LED swap/Projector retrofit/ Built trans/ FTI 2800 stall/Punisher comp VB.
10 Focus coupe 5 speed /80PRS/Obsidian audio 12s/AQ1200D/AQ6.5s/AQ120.4/Alpha Damped/ 2 batteries/All KnuKonceptz wiring/Projector retrofit/LED tails/
  #5 (permalink)
Old 05-09-2011, 06:23 PM
FlaresideF150's Avatar
FlaresideF150 FlaresideF150 is offline
1995 Ford F-150
FlaresideF150 is starting off with a positive reputation.
LMC and BroncoGraveyard has everything you will ever need for your truck including drop shackles.
  #6 (permalink)
Old 05-18-2011, 09:30 PM
Thanks, I can't ever find anything on TTB trucks. I used to see ad's in magazines and online but mostly for prerunner/offroad i beams. I read somewhere thy also had increased steering ratios. Are they're sway's bigger than f250s?
  #7 (permalink)
Old 05-18-2011, 09:39 PM
1992 Ford F-150
I-Beams-$599 3"
Drop Shackles and Hangers-$259 4"
Axle flip kit-4-5"
Lowering coils-2"
Lightning Coils-1"
Those measurements are going from a factory truck, and adding them....The coils/beams will give you 5" of static drop...and the flip kit, and lowering shackle, etc will give you 7-9" of drop...
With the flip kit, you'll need to do some C-Notch work...
__________________
Wesley
  #8 (permalink)
Old 05-20-2011, 12:14 PM
Copper head Copper head is offline
Copper head is starting off with a positive reputation.
Every now & then you can find factory 93-95 Lightning springs for sale on the NLOC & Lightning Rodder.
Just have to keep your eyes open.
  #9 (permalink)
Old 06-12-2011, 06:48 PM
95 F150 Dude 95 F150 Dude is offline
2009 Ford F-150
95 F150 Dude is starting off with a positive reputation.
Copper head,
If you're still in the market for the Gen 1 springs, I have a rear pair and the factory rear sway bar.
Scott
  #10 (permalink)
Old 06-12-2011, 08:27 PM
1992 Ford F-150
95 f150 Dude-PM me about the sway bar....
__________________
Wesley
  #11 (permalink)
Old 07-01-2011, 04:16 AM
I-Beams-$599 3"
Axle flip kit-4-5"
Lowering coils-2"
Lightning Coils-1"
Yeah, I was afraid of that. I'm trying to kinda recreate the Lightning Bronco. and it seems as though an axle over setup wouldn't work. I'd need to keep it axle under and do a small C-notch, probably loose a few leaves.
  #12 (permalink)
Old 07-01-2011, 05:08 AM
1992 Ford F-150
I did find the dream beams for a mere $345 per set...I'll have to find the link again...
__________________
Wesley
  #13 (permalink)
Old 09-06-2011, 07:47 PM
Guitarbuddy Guitarbuddy is offline
Guitarbuddy is starting off with a positive reputation.
Lightning ft springs
I have a pair of 94 Lightning front springs for sale. These will lower and stiffen a F150 a lot.
  #14 (permalink)
Old 11-15-2011, 06:03 AM
03greygt 03greygt is offline
03greygt is starting off with a positive reputation.
Do you still have the Lightning springs?
  #15 (permalink)
Old 11-15-2011, 10:43 PM
Yes, I still have them. $100 shipped. my Paypal is johnconnie75@hotmail.com
Tags
150, 1996, 1st, amount, ford, gas, gen, kit, lightning, lmc, lowered, lowering, mag, mileage, oil, reliability, shackles
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
