04 Fog install Question; New bumper, lights, harness; pics pics pics
I agree with fox, the oem headlight switch with the pull out for fogs is pretty expensive. This should help:
1 W505424-S301 Hood release retaining bolt
2 16B975 Hood release assembly
3 W505424-S301 Front bumper cover-to-front bumper bolts (3 required)
4 — Hood over-slam bumper retaining bolts (2 required)
5 — Hood over-slam bumpers (2 required)
6 — Air dam pin-type retainers (3 required)
7 180101-12A581 Fog light electrical connectors (if equipped)
8 N804525-S427 Frame mounting bracket-to-front bumper nuts (4 required)
9 W706599-S427 Front bumper
Remove the hood release retaining bolt.
Position aside the hood release assembly.
Disconnect the hood release cable routing retainer.
Remove the 3 front bumper cover-to-front bumper bolts.
Remove the hood-over slam bumper bolts.
Remove the hood-over slam bumpers.
Remove the 3 air dam pin-type retainers.
If equipped, disconnect the fog lamp electrical connectors.
Remove the 4 bumper mounting bracket-to-front bumper nuts.
To install, tighten to 115 Nm (85 lb-ft).
Remove the front bumper.
To install, reverse the removal procedure.
Transfer components as necessary
bigwin56f100
07-19-2015 06:13 PM
2many56s
06-12-2015 06:44 PM
bigwin56f100
03-25-2015 10:16 AM
Relixx
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
05-24-2010 07:07 PM
