Granny Tranny
Old 04-28-2011, 10:06 PM
Jack Scandia's Avatar
Jack Scandia
Jack Scandia is offline
Granny Tranny
I have a 1996 f250/7.5 with 180k on her. had it for 3 months,
and it runs great but recently started pulling my bobcat with and it leaks tranny fluid like crazy. Drop the trailer it stops ??? Any one have any thoughts on why and what I need to do to fix it. Thanks in advance for any help.
Old 04-29-2011, 01:13 AM
redmondjp's Avatar
redmondjp
redmondjp is offline
Is the transmission leaking or is it blowing out the dipstick tube?
I'd guess that you're getting slippage while towing which is overheating your tranny fluid - you do have an automatic, correct? It could be that the extra-hot fluid is leaking out of a rubber cooler line or past a seal as well.
I would discontinue any further towing until you figure out what is going on. Have you checked your fluid level, color, and smell? If it's burnt, you'll see it AND smell it!
Assuming that your transmission is in perfect condition, as a minimum you would want a supplementary transmission fluid cooler AND a transmission fluid temperature gauge (sensor goes in the pan) if you're going to be towing heavy loads. Keep it out of overdrive as well while towing.
I have a good friend who had a side job towing new camp trailers all over the west coast in his late 90s F250 - toasted his automatic due to failure to heed the advice above. Got ticked off (after getting stranded and then getting stiffed with the tranny rebuild & R&R bill) with it and replaced with a 5-speed manual behind a Cummins in a Dodge dually!
Old 04-29-2011, 07:04 AM
rquinlans's Avatar
rquinlans
rquinlans is offline
Don't know what your bobcat weighs but I know towing mine a one ton is required in kansas.
grumpyinme.
11-08-2016 07:46 AM
Kerryandhis1989f150
05-31-2015 10:25 PM
philbax
11-23-2007 09:12 AM
SMS888
08-30-2007 11:55 PM
Fishallot
1978 - 1996 Big Bronco
16
10-13-2005 10:39 PM
Quick Reply: Granny Tranny
