evacuating oil from injectors
Old 04-28-2011, 02:11 PM
hedhntr's Avatar
hedhntr
hedhntr is offline
yesterday i pulled all the injectors and stuck shop towels in each hole, before i got a chance to pump all the oil out i got a call and had to leave. is it okay not to suck the oil out right away, i wont get a chance till the morning
Old 04-28-2011, 02:15 PM
Robbgt's Avatar
Robbgt
Robbgt is offline
I had mine out for a day before I got around to it. Oil just settles down into the cylinder. I used a 60cc syringe and a length of 1/4" tubing to suck as much out as I could. You could also, when re-installing, install the injectors, but leave the gp's out. then throw the VC's on with a couple bolts. Pull the IDM maxi fuse and bump the starter over a few times. This will send any extra oil out the GP hole and back through the heads.
I did both, just as insurance
Old 04-28-2011, 08:15 PM
JamesHajek's Avatar
JamesHajek
JamesHajek is offline
^^^^What he said... Change your oil after though because there will be fuel mixed with the oil when shooting the oil out of the cylinders...
4x4countryboy
05-06-2012 10:41 AM
fordpride
03-10-2011 08:45 PM
rmalottwtes30
10-11-2010 09:58 AM
MICHAEL34
09-29-2009 09:40 PM
69 stang
07-02-2009 10:22 PM
Quick Reply: evacuating oil from injectors
