You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Hey yall, I have some play in my ps box and i read there is a screw u can adjust to have less play. How much should i turn it and what direction? Thanks.
__________________
1992 Ford F-250 XLT 7.3 IDI 115K, 4X4, ZF5 S5-47 w/ 12inch clutch and SMF, Banks wastegated sidewinder turbo, 6637, BB injectors, rebuilt IP w/ fuel turned up, 3 inch DP, custom 3.5 inch exhaust with 4 inch tailpipe, 285/75/16R Yokohama's on PSD alcoas. Rebuilt D60 w/ firestone airbags. 10.25 sterling rear w/4:10's LS, Three pillar gauges with pyrometer, boost, and transmission temperature. Onboard air w/ 400C Viair. 16K rated B&W trailer hitch. Sound-tracker CB w/ 4 ft firestik.
If you choose to adjust it by trial and error, you loosen the lock nut and with a
flat blade screwdriver turn the screw clockwise to take up any slack. Don't
turn the screw more than 1/8 of a turn at a time. Take it for a test drive and
adjust again if needed. Warning if you tighten the screw to much, you can
lock up the steering box.
