Part # for 95 F350 hub? - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 04-28-2011, 08:21 AM
german41274 german41274 is offline
german41274 is starting off with a positive reputation.
Does anyone have a part number for the front hub on a 4x4 f350 7.3L non-dually 4 dr. Thanks
Old 04-28-2011, 08:29 AM
Cuda_jim's Avatar
Cuda_jim Cuda_jim is offline
Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.
I assume you mean the thing you turn for 4x4. Auto or manual hubs.
The autos are prone to breakage and are usually replaced with a set of warn manuals.
Auto hub diagram:
Old 04-28-2011, 04:58 PM
78pace's Avatar
78pace 78pace is offline
78pace is starting off with a positive reputation.
If I could fine Dually ones I would have a pair for you.
Old 04-28-2011, 06:15 PM
Cuda_jim's Avatar
I have a pair of OEM auto hubs that were replaced after one of them failed about ten years ago. One small part will get them going again.
The Warn Manual hubs are bullet proof.....so far
Old 04-29-2011, 04:58 PM
it's number 8 on the diagram. a guy did my brakes and didn't properly seat the studs and ruined the hub or whatever you call number 8. on my truck the rotor, hub and studs are all seperate.
Old 04-30-2011, 06:37 AM
Cuda_jim's Avatar
Which one do you need? #8 consists of 2 pieces.
The brake rotor and the hub assembly.
They can be purchased at most part stores.
Hub assembly w/o the wheel studs:
Rotor: MOTORCRAFT Part#'s BRR4 or YC3J2C502AA or YC3Z1V125AA
Front hub locks N$$ 1987 - 1996 F150 & Larger F-Series Trucks 8 12-23-2013 01:03 AM
Axles? Hubs? Truck Guy99 1987 - 1996 F150 & Larger F-Series Trucks 4 09-08-2013 09:57 AM
Bad Hubs? MtHydro Clutch, Transmission, Differential, Axle & Transfer Case 10 03-06-2012 11:40 PM
Hubs 2008 f-350 John Pato 1999 to 2016 Super Duty 1 08-05-2011 11:41 AM
f350 dually 4x4 hubs?? mrblonde108 1987 - 1996 F150 & Larger F-Series Trucks 9 10-02-2010 11:47 AM
Tags
03, 08, 350, 95, 96, auto, automatic, diagram, explorer, f250, f350, ford, hub, hubs, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
