Can ARP studs be installed without removing the heads? - Ford Truck Enthusiasts Forums
Old 04-28-2011, 03:58 AM
lhansman lhansman is offline
lhansman is starting off with a positive reputation.
I have an '04 6.0 liter with about 300,000 kms on it and a couple of injectors that need replacing. Given the mileage on my vehicle it has been suggested that I replace all eight due to the labour costs involved with getting at the injectors under the valve covers.
After having two EGR's replaced I had the EGR deleted, installed a new oil cooler, coolant filter and SCT tunes and now am very pleased with the performance and fuel economy of the truck. I do not want to purchase a new (or newer) truck at this time so I am looking to prolong the life of my 6.0 liter.
The dealer tells me that they will be lifting the cab off to do all of the injectors so I'm thinking that I might as well do the ARP studs while they are in there. Can the existing bolts be removed and the ARP studs inserted without having to remove the exhaust headers, heads and replacing the head gaskets?
I had to have the FICM replaced last November and had a leak in the HPOP fittings for the fuel injectors under the valve covers so I had all of those parts replaced at the same time. If I am this far into the 6.0 liter, is there anything else you folks would recommend I do while it is wide open?
I am hoping to get another 200,000 - 300,000 out of the truck once this work is completed.
Old 04-28-2011, 08:38 AM
counciller's Avatar
counciller counciller is offline
counciller is starting off with a positive reputation.
subscribing
Old 04-28-2011, 08:47 AM
texans's Avatar
texans texans is offline
texans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to behold
It can and has been done, but it is not a very wise choise at this point in the game! If you go as far as to take the head bolts out then the only real step your skipping is replacing the HG's, and having the heads checked. There is no real reason to half a$$ the job your not even really talking about that much more labor to do it the right way. There is no real way to tell if your HG's are still in perfect condtion. Then you will end up redoing the job. IMHO it is a really bad idea to due studs, and not replace the $75 HG.
On a side note if your dealer is saying they have to lift the cab to do injectors, run, run really fast to another shop. That is not only un-heard of, it's just plane stupid to lift a cab for injectors.
Old 04-28-2011, 09:51 AM
LOOnatic LOOnatic is offline
LOOnatic is starting off with a positive reputation.
Quote:
^^^ Yep. You dont have to pull the cab to change injectors so that part doesn't make sense.
I have an 04 also and i have thought about changing 1 headbolt at a time with arp but in the end it is wise to go ahead and pull/inspect heads and install fresh gaskets so that its good once and for all.
Old 04-28-2011, 12:11 PM
rdunagan's Avatar
rdunagan rdunagan is offline
rdunagan is gaining momentum as a positive member of FTE.rdunagan is gaining momentum as a positive member of FTE.
X3 on running. you dont have to pull the cab. thats why in your other thread the labor is so high. if you do the head gaskets you should be able to get outta the dealership for about 5k or so. thats with studs and then just add the cost of injectors as the shouldnt charge you for the labor on them to replace because they have to pull them anyways.
Old 04-28-2011, 05:09 PM
2006powerstroke90's Avatar
2006powerstroke90 2006powerstroke90 is offline
2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.
I am a little curious about how one would go about doing studs w/o removing the heads....
I know I couldn't get a stud in unless I held it up while setting the head down...
Old 04-28-2011, 05:29 PM
texans's Avatar
there was a member that did it by taking out the motor mounts and tilting the motor to one side to make it work. Do a search for ARP studs without removing heads. I will see if I can dig it up for you. I still stand behind the fact that it is not a very good idea. Just doesn't make much since to do it that way.
edit...here you go http://www.ford-trucks.com/forums/84...-hvac-box.html
Old 04-28-2011, 05:34 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
pretty much how its done. even with bolts there are a few that we have to tie up and set with the head
Old 04-28-2011, 09:30 PM
Curt's05's Avatar
Curt's05 Curt's05 is offline
Wiser by FTE
Curt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud of
I did it one bolt to stud 1at a time, why replace good head gaskets? A post by another fte member showed my the way. The pass side rear bolt won't come
out without twisting the engine or removing heater box/core, at lest on an 05 ex.
Old 04-28-2011, 09:46 PM
cheezit's Avatar
just remove the trans mount and cross member and move te motor as needed.and it the drivers side rear thats the issue.
Old 04-28-2011, 09:54 PM
m-chan68's Avatar
m-chan68 m-chan68 is online now
m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.
First off, add me to the list that will advise you to RUN if the dealer you are taking it to, tell you that the cab needs to be removed to replace injectors. What's the name of the dealer? (I live in Brampton and work in Toronto)
Although some may disagree, I lift cabs only when removing either the engine itself or the cylinder heads. Some say, it's quicker to leave the cab bolted to the frame to remove cylinder heads, I say for the relative ease there is to removing the cab, why put one's body through more torture than needed. Those of you guys doing this job on your own rides on your driveways may end up doing this job only once. But for us techs, we do it multiple times.
BTW, I also disagree with gambling by attempting install one at a time.
Old 05-01-2011, 07:35 AM
I live near Orangeville so the dealer I use is Blackstock m-chan68. Prior to the warranty expiring, my truck had the turbo replaced and the EGR was done twice. At 158,000kms the heads were removed due to coolant leaks but Blackstock would not install ARP studs for me since the job was being done under factory warranty.
The truck is running fine since the EGR delete and installation of the SCT tunes. Despite the huge repair bills I actually like the truck now. What do you think it should cost to replace all eight injectors and install new head gaskets and ARP studs?
I am not tied to Blackstock and except for a rough idle for the first couple of minutes (due to the two faulty injectors) there is no rush.
Old 05-01-2011, 12:17 PM
rdunagan's Avatar
you should only have to pay for the head job labor. the injectors you should just have to buy being that they have to pull the injectors out anyways. so that being said on the labor part all you would have to pay is for the head job. you would have to buy the studs and take them to the dealer more than likely
HELP! Myster stutter and stalling etdavenport 1999 to 2016 Super Duty 1 09-23-2016 06:53 PM
Please help! 6.0 blowing white smoke. steve green 6.0L Power Stroke Diesel 7 10-31-2015 04:42 AM
Defective fuel injectors - replace 2 or all 8 lhansman 6.0L Power Stroke Diesel 21 08-20-2014 08:14 PM
Good price for 6.0 Ford fuel injectors in Toronto area lhansman 6.0L Power Stroke Diesel 3 04-02-2011 01:51 PM
Replacing Head Bolts with ARP Studs Question DSMMH 6.0L Power Stroke Diesel 18 07-10-2010 08:11 AM
Tags
60, 60l, arp, cab, changing, diesel, ford, head, injectors, lifting, liter, powerstroke, removing, replace, studs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
