'87 - '96 5spd - Ford Truck Enthusiasts Forums
'87 - '96 5spd
Old 04-28-2011, 02:00 AM
fyerser fyerser is offline
fyerser is starting off with a positive reputation.
'87 - '96 5spd
I have a '95 Bronco 4x4 that came original with an automatic, but someone swapped in an NP435 4spd. They kept all the factory wiring under the truck, even the transmission lines. I've found a 5spd with transfer case that supposedly fits '87 - '96 f150/broncos to put in it. Is that 5spd the same throughout those years? And how different is the wiring on a '95 between a std trans and an auto? I'd like to wire the 5spd to my factory auto's harness so my speedo works and hopefully knock my check engine light off.
Old 04-28-2011, 03:03 AM
68Shortbox5.4's Avatar
68Shortbox5.4 68Shortbox5.4 is offline
68Shortbox5.4 is starting off with a positive reputation.
There are two different five spds, one for half tons I believe it is the M5R4, and the ZF series, if you can get the zf. It is much stronger, handles a lot more torque but is much harder to find
Old 04-28-2011, 03:24 AM
75Three90's Avatar
75Three90 75Three90 is offline
75Three90 has a great reputation on FTE.75Three90 has a great reputation on FTE.75Three90 has a great reputation on FTE.75Three90 has a great reputation on FTE.
68shortbox is correct the zf5 is much stronger came behind 351's 300's and 302's that were 3/4 the NP435 should bolt to either one of the two trannys SHOULD if not i have a BW1345 ive been trying to un *** for awhile that still works your going to have to get a new computer or another one and the new wiring for that tranny fly wheel flex plate possibly drive shaft and is tyours mechanical clutch? if so all the hydralic clutch system it would be cheaper to put an autop back in it than it would to transfer everything to standard just my .02 but it would be easier to find a donor truck i hope this helps
Old 04-28-2011, 03:30 AM
I have a guy around the corner who is parting one out with the zf, if I didn't have the 7.3 I'd buy it for a spare just because around here people want an arm and a leg for those zfs
Old 04-28-2011, 03:35 AM
75Three90's Avatar
ohhh yeah id love to have the entire truck those parts would look good under the hood of my 1979 F350
Old 04-28-2011, 04:07 AM
NP435 is the transmission, still has pushbutton 13-56. The 5spd i've found locally is a half-ton 5spd. Mine does have hydraulic clutch on it. As far as swapping computers, do you mean to get my speedo to work? It has the NP435 4spd in it now, with the factory harness for an auto, and it runs and drives great, aside from my check engine light being on. But the 4spd is tore up pretty bad, jumps out of first, and grinds everytime you shift, i took off the cover and it's a mess inside, needs a few new gears in it. But i'd like to have the 5spd in it for the OD primarily, not that i'll be spending alot of time in OD, tires are pretty big.
Old 04-28-2011, 04:11 AM
75Three90's Avatar
for the check engine light to go off tyour going to need the new computer cause the motor is still reading you have a E4od and is throwing codes just get a puter that is meant for a standard and all should be good does your have a speed-o cable or a sensor?
Old 04-28-2011, 05:57 AM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
The speedometer should be electronically driven using the speed sensor on the rear axle. The transmission is irrelevant in this case - there's something else wrong that's causing the speedometer issue.
If the NP435 uses an external hydraulic slave cylinder, you will need a new hydraulic line to match the 5-speed since it uses an internal slave cylinder concentric with the input shaft of the transmission and has a different fitting. The clutch components should work with both transmissions as long as the spline count on the clutch disc is the same (I think it should be).
87-96 obs truck parts fordka Ford Truck Parts for Sale 57 09-13-2015 01:46 PM
87-96 obs parts galore fordka Ford Truck Parts for Sale 7 02-23-2015 04:47 PM
what mileage is your 302 truck getting? bbf150 1987 - 1996 F150 & Larger F-Series Trucks 41 05-14-2008 01:31 AM
85 BII Auto to 5 spd Switch 018261 Bronco II 2 08-28-2005 08:10 PM
swapping the auto for a 5spd..? 65kcoupe 1978 - 1996 Big Bronco 1 06-15-2003 11:51 PM
Tags
1987, 302, 87, 8796, 96, bronco, engine, f150, f250, f350, fit, ford, series, spd, specs, speed, speedometer, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
