What tires and wheels fit and what ones hit - Page 2 - Ford Truck Enthusiasts Forums
Old 05-02-2011, 12:22 PM
thejean's Avatar
thejean thejean is offline
thejean is gaining momentum as a positive member of FTE.thejean is gaining momentum as a positive member of FTE.
I'm thinking 2.5" leveling up front, 1" lift in the back, no fender flares, maybe spacers and meaty AT tires with a bit of sidewall bulge.
Won't be super agressive but also won't cost a small fortune.
Old 05-02-2011, 03:31 PM
sy628109 sy628109 is offline
sy628109 is starting off with a positive reputation.
The only difference I had in mind is 2" up front, keep the back stock (I have a 250 w/fx4). The wheels are really my only concern, not a huge fan of any of the aftermarket wheels out there...wish I had been pickier at the dealer with this and not having the chrome package, only regrets.
Old 05-02-2011, 06:03 PM
thejean's Avatar
I'm with you. The aftermarket wheels are all bit too bling for my tastes. But I may buy some ATs that fit the stockers and if I don't like the look can then grab some aftermarket wheels and swap the tires on. Keep the stock wheels for winter tires or try to sell them.
Old 05-02-2011, 06:04 PM
thejean's Avatar
PS - who makes a 2" leveling kit? I like that idea.
Old 05-02-2011, 07:32 PM
when i had my f150 i used auto spring, it was quick and simple installation. I saw that some guys on here have used it on their super duties as well. From what i have read, unless it comes with a new traction bar most kits will require some caster correction, so unless i get some compelling reason from some one, i will use auto spring again.
Old 05-02-2011, 07:45 PM
EpicCowlick's Avatar
EpicCowlick EpicCowlick is offline
EpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant future
Quote:
Right on all accounts but remember the trac bar is for re-centering the axle. A two inch level on my truck shifted the axle about 1/2 inch off center. Just enough to show about 2 degrees off on the steering wheel. Looking at the truck from the front, you can just see the driver side tire is a little more to the outside of the fender than the passenger side. I haven't gotten around to replacing the trac bar is it does not affect drive-ability.
The caster angle on the other hand is another matter. By raising my front end, it effectively removed the caster angle and the steering was loosey-goosey. I asked the alignment shop to not only restore the factory setting but also add an additional half to three quarters of a degree. I prefer a little more resistance in the steering wheel so that was good for me.
FYI - on the second photo in my post above you can see the AutoSpring 2 inch spacer on top of the coil.
Old 05-03-2011, 06:25 AM
11350KINGRANCH's Avatar
11350KINGRANCH 11350KINGRANCH is offline
11350KINGRANCH is starting off with a positive reputation.
Mine has the 2" Auto Spring as well. The truck will definitely need an alignment after you put it on.
Old 05-03-2011, 10:47 PM
thejean's Avatar
So here is the lifted white truck and the same truck in black. These wheels definitely work better on a black truck:
Although, looking at some of the other pics, I think the fender flares are way too much for the stock wheel offset. Looks a bit like a railroad truck.
Old 05-04-2011, 04:09 PM
btm991 btm991 is offline
btm991 is starting off with a positive reputation.
How do you know what off set to get when you are buying rims, also what backspacing?
Old 05-04-2011, 07:01 PM
thejean's Avatar
Update: I just saw a blue '11 with the stock 18's and some meaty tires with no leveling kit or fender flares. Looked awesome! Simple yet effective in making the look very agressive. A leveling kit would enhance that look even more I would think.
Old 05-04-2011, 07:04 PM
thejean- good photoshop skills!!!!
Old 05-09-2011, 01:06 AM
thejean's Avatar
^^^THanks!
Saw two amazing Tuxedo black 350's this weekend. The first was lifted at least 6", had bushwacker bolted flares, massive wheels and tires and an awesome looking bush bumper. It came up behind me and I felt inadequate in my stock 350.
Second one has maybe a 3" or 4" lift, nice chrome wheels and bushwacker bolted flares as well. Also loked really nice. Altough I think he should have gone with less offset and no flares unless for a more clean look. The flares didn't really jive with the wheels. Or maybe the non-bolted flares at least. However, still gorgeous trucks. I gotta do something to mine to jazz it up now... or trade in on a dually!
Speaking of which, also saw a brown 450 KR with the gold trime along the bottom - simply breathtaking.
  #28
Old 05-09-2011, 09:57 AM
I figured out my plan and what I don't like about the stock 18's.....they make the truck look cheap, I am sure it's partially due to the garbage continental tires, but I am 99% sure I will be getting rid of the wheels.
My plan is to put a 2" level on the front, 4" blocks on the back (its a 250) then to either get factory 20's or put 18" XD Misfits on there, the truck is silver:
WHEELS | KMC Wheels | Page 3
Do you think there will be too much sidewall with 35" tires and 18" wheels?
Anyone with 11.5"+ wide tires mind posting a pic of the truck from the front to show how much they stick out on these new trucks? Optional Body molding or no?
Thanks
  #29
Old 05-09-2011, 01:47 PM
thejean's Avatar
Can't comment on your sidewall question but the wheels you selected sure look nice!
  #30
Old 05-09-2011, 04:49 PM
kereams kereams is offline
kereams is starting off with a positive reputation.
Problem with most of those after market wheels is their weight rating is significantly less than the stockers. If its under 3500lb per wheel I would keep looking, especially for a 350.
Anyone with 325/60/20 on stock suspension zs11SD 1999 to 2016 Super Duty 1 02-09-2016 08:01 AM
2011 F250 Tire size? (stock) firebus 1999 to 2016 Super Duty 2 10-24-2014 04:56 PM
2011-2014 Tire Size with 2.5" Leveling Kit 2012 F350kranch 1999 to 2016 Super Duty 4 08-23-2013 01:24 PM
Autospring Leveling Kit with Which Tires? '78F250351m 2009 - 2014 F150 2 07-11-2013 12:11 PM
2011 ranger tire size Xistenz Ranger & B-Series 8 12-08-2010 04:31 PM
Tags
20, 2856520, 3156020, connect, cost, duty, f150, fit, ford, forum, inch, replacing, stock, super, tires, toyo, transit, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
