Dana 60 rear, axle vent tube seal? - Ford Truck Enthusiasts Forums
Old 04-27-2011, 11:08 PM
wyckedcombo17's Avatar
wyckedcombo17 wyckedcombo17 is offline
wyckedcombo17 is gaining momentum as a positive member of FTE.
So three days later and I'm still in the midst of my brake job.
Basically my brakes were held together by grime and rust. Naturally the more I fix the more I break off.
Meet my latest victim, the axle vent tube:
I had to go at the sucker pretty good with the vice grips and metric deep sockets. I think I eventually ended up getting a 1/2" on there, or maybe it was 13mm. Anyway, I'm ordering a new one from JBG. Is this the right one? Does it look like it'll work in the old brake hose? It's the same size as the old one, just possibly longer. I can shim it up with washers if that's the case
Lastly, when I put that tube back on, should I seal the threads up with some black RTV?
Old 04-28-2011, 07:44 AM
grinnergetter's Avatar
grinnergetter grinnergetter is offline
grinnergetter has a good reputation on FTE.grinnergetter has a good reputation on FTE.
If I remember right I had to shim my rear also. I used a nylon washer to get the height correct and thread sealant. I'm sure RTV would be fine.
Old 04-28-2011, 08:03 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
E7TZ-4022-A (replaced E3TZ-4022-D, D1OZ-4022-A, C2OZ-4022-A, C0DD-4022-A, B7A-4022-A & 8A-4022) .. Rear Axle Vent / 7/16" -20 x 2 1/8"
Fits myriad 1949/96 Passenger Cars / 1948/96 F100/350's / 1961/96 Econolines / 1966/96 Bronco's.
Old 04-28-2011, 01:14 PM
Good deal with the RTV.
Bill, does Ford or Dana/Spicer still make that part then? Would I have been able to pick it up at the local dealer?
Old 04-29-2011, 01:58 AM
Quote:
Ford just obsoleted E7TZ-4022-A / Two Ford Dealers in IL have ONE each:
ROBINSON FORD in Robinson IL = 618-546-5440.
J. WILDERMAN AUTOPLEX in Mt Carmel IL = 618-262-5161.
400 Roller Rocker issues wyckedcombo17 1973 - 1979 F-100 & Larger F-Series Trucks 0 06-08-2013 02:23 PM
H4 upgrade wyckedcombo17 1973 - 1979 F-100 & Larger F-Series Trucks 19 12-13-2012 01:18 PM
Project: One color on a budget (and rust ain't a color) wyckedcombo17 1973 - 1979 F-100 & Larger F-Series Trucks 195 05-16-2012 12:06 AM
'65 in Chicago salvage yard wyckedcombo17 1961 - 1966 F-100 & Larger F-Series Trucks 6 04-22-2012 12:56 AM
2 Different parking brake cables? Pictures wyckedcombo17 1973 - 1979 F-100 & Larger F-Series Trucks 11 04-21-2011 12:31 AM
Tags
2004, 40, 60, axe, axle, breather, dana, end, enda, f250, f350, ford, rear, service, tube, vent
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
