Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1987 - 1996 F150 & Larger F-Series Trucks 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucksSPONSORED BY:
  #1 (permalink)
Old 04-27-2011, 09:49 PM
nebechanezer's Avatar
nebechanezer nebechanezer is offline
Garage is empty, add now
nebechanezer is starting off with a positive reputation.
schematic needed for power distribution box
like the title says, for a '95 f-350 w/ 460 e4od, specifically looking for the yellow w/ gray tracer going into relay 3. Thanks.
__________________
1995 F-350 CC flatbed 4X4, 460/E4OD
2005 Freestar
  #2 (permalink)
Old 04-28-2011, 08:43 AM
subford's Avatar
subford subford is offline
subford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to behold
Quote:
Schematic, you are looking for wire #6 & plug/Relay #56:
Click the image to open in full size.
__________________
95 F150 302 4R70W EB EX-CAB
94 F53 460 E4OD COACHMEN SANTARA RV
83 F150 Flare Side 351W AOD
77 F250 351M-2V NP 435/4 Speed 4X4
subford@gmail.com
Bill K, Kansas Chapter
  #3 (permalink)
Old 04-28-2011, 09:58 PM
thanks for the response. Something isn't jiving here though. The wire i'm working on could be y/lb, looks y/gy to me. The relay terminal is 58, 56 is yellow/ light green to the horns. 6 is 12v to fuse. In your bottom pic, it shows a "t" in the y/lb , so that 57 and 58 both have 12v off the same fuse, but on mine 5 goes to 57 and 58 comes from the loom, and i dont know where it goes. It does not have 12v to power the relay coil, but 58 does, since it comes off the horn fuse. Thats why my horn doesn't work, but i dont know where 57's y/lb goes. It all looks stock and unaltered, and i know i could just splice into 5's wire to power the coil, but i'd like to find out how its supposed to be.
__________________
2005 Freestar
  #4 (permalink)
Old 04-29-2011, 08:38 AM
subford's Avatar
Not sure what you are calling 5 but may be the diagrams below will clear it up.
The point numbers in the diagram are your terminal numbers.
The bottom image above was for a 1993 and the one below is for a 1995.
The detail schematic above is for your 1995.
The Yellow wire with a blue stripe you speak of runs about 1 foot into the harness and is spliced with three black wires with an orange stripe. The splice is the black dot in the detail schematic above in the lines below the box.
One of the black wires with an orange stripe runs back to point 5 at the fuse to give the Yellow wire with a blue stripe power and at the same point the other Yellow wire with a blue stripe also gets its power there.
__________________
subford@gmail.com
  #5 (permalink)
Old 04-29-2011, 07:49 PM
thank you very much, that should help clear things up. I'll take a look at that splice tonight.
__________________
2005 Freestar
  #6 (permalink)
Old 04-30-2011, 10:51 AM
Thanks again! Found it, was a bad spot in the y/lb after the splice on its way back to the distribution box. I don't know how that happens, everything was factory sealed well and there wasn't any damage to any other wires. Horn works now, hoping the cruise works when i get everything back together. On a side note, what are the 2 relays in the box next to the distribution box?
edit:I think i figured it out, after seeing some trailer wiring diagrams you posted today. i bet it's my trailer batt. charge and b/u light relays.
__________________
2005 Freestar
Last edited by nebechanezer; 04-30-2011 at 12:52 PM. Reason: answered my own question
  #7 (permalink)
Old 04-30-2011, 01:21 PM
subford's Avatar
You are right on the relays.
__________________
subford@gmail.com
  #8 (permalink)
Old 04-30-2011, 02:08 PM
subford's Avatar
Here is an image of them and the plugs for it.
__________________
subford@gmail.com
Tags
1994, 1999, 73, 97, 99, box, diagram, distribution, expedition, f250, f350, ford, junction, power, problems
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
