Combustion Gas in Coolant - Ford Truck Enthusiasts Forums
Old 04-27-2011, 08:51 PM
Scott6.0PSD's Avatar
Scott6.0PSD Scott6.0PSD is offline
Scott6.0PSD is starting off with a positive reputation.
I've been monitoring my coolant pressure and from reading various posts on this forum, I decided to try the combustion gas test. Using leak tester from Napa with the blue fluid.
Well the fluid turned yellowish-green - a positive reading.
I've read that this can be caused by leaking head gaskets or possibly some form of an EGR cooler failure-though not sure how. Are there any other ways that combustion gas could get into the coolant?
Some other observations/points that may be relevant are:
  • gas test performed at 1200 rpm (high idle mod)
  • coolant pressure seems to be running between 12-14 psi, however if I relieve the pressure when cold, it will build to 6-7 psi hot, until stepping on it, at which point it will get back to the 12-14 psi range.
  • i do not hear any tea kettle noises, nor see it rise over 16 psi at WOT
  • it will puke when loaded with truck-camper
  • tech performed TSB 09-08-03, with no failure results
  • initially smokes on cold start - video posted in another post (http://www.ford-trucks.com/forums/10...l#post10264415)
Any help is appreciated
Old 04-27-2011, 08:57 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
have you parked the truck on a hill nose down and pulled the egr valve check the chamber it sits in it should be dry
is there any oil in the coolant bottle
yes combustion gas can come from either a bad head,bad egr cooler, streched head bolts,bad head gasket
cheezit had that vidio not to long ago
Old 04-28-2011, 06:09 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
refer to tsb 09 08 03 for this concern.
Old 04-28-2011, 09:33 PM
Quote:
Dealer perform the TSB, said everything was "normal". They could not reproduce the puking. I looked at the TSB and didn't see any mention of testing for combustion gases. Does this mean that some exhaust in the coolant is acceptable Or is it that they didn't perform the TSB correctly?
Thanks,
Scott
Old 04-28-2011, 09:39 PM
I'll check the EGR valve this weekend.
I should have also noted that I do not have white smoke.
Is there any other way that combustion gases could get in the coolant? For instance with the injectors, etc.
Thanks,
Scott
Old 04-28-2011, 09:44 PM
cheezit's Avatar
I would suggest that you may want to hook up a pressure gauge in line with the degas bottle. also I would look at ect eot splits.
The chemical test is not the most accurate out there. you can also try to find a shop with a 5 gas that also works pretty well
Old 04-28-2011, 09:56 PM
I'm using the Dashdaq with a coolant pressure sensor at the degas bottle. Readings generally are between 12-14 psi, except at WOT.
EOT-ECT delta is 6 psi around town and 11 psi on the highway. Only time I've seen it go above 15 is after cresting a hill, where the ECT drops faster than the EOT.
I've read where the gas test could have false negative, but didn't know they could also have false positive readings. What is a 5 gas?
Thanks again
Old 04-28-2011, 09:59 PM
cheezit's Avatar
ok so what is the pressure in the tank at WOT. imo this may be were you issue is comming from.
A 5 gas analizer is used in emmision testing for IM240 states (think califorina smog testing)
one of the issues with the chemical test is deloution by sucking up any coolant, another is the age of the checmical.
Old 04-28-2011, 11:12 PM
ZeroTucker's Avatar
ZeroTucker ZeroTucker is offline
ZeroTucker is starting off with a positive reputation.
My truck was puking, but only sometimes at WOT or while towing. I'm sure that it started as stretched head bolts which lead to head gasket failure.
My shop was able to make the determination after about a day of diagnostics. If your shop is telling you they can't find anything wrong, I would suggest finding a new shop...
Old 05-01-2011, 08:14 PM
Parked it overnight, nose down. Here is a picture of the manifold:
Ford Truck Enthusiasts Forums - Scott6.0PSD's Album: EGR - Picture
And another of a finger swipe:
Felt more oily, but maybe this is the exhaust soot. I couldn't smell coolant, but I don't have the best sniffer either.
Oh, and no oil noticed in the coolant.
Old 05-01-2011, 08:21 PM
rdunagan's Avatar
rdunagan rdunagan is offline
rdunagan is gaining momentum as a positive member of FTE.rdunagan is gaining momentum as a positive member of FTE.
egr cooler is going IMO. thats what happend to me. i caught mine while it was in the wet stage and not the flooding stage like most. pulled mine off and coolant was coming out both ends. id say its time for a new one. BPD imo
Old 05-01-2011, 08:22 PM
bismic's Avatar
bismic bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
What coolant are you using and is it at 50/50 concentration?
Early on, my EGR valve had oily sticky fouling. It was combustion related. A new valve, new flash updates, reduced idle time, and a good fuel additive solved that problem. Your EGR material looks like mine did.
Old 05-01-2011, 08:28 PM
WOT, the pressure gets to 16ish. I haven't had the gauge installed long enough to see what the pressure is with the loaded camper (where it would typically puke).
For the gas tester, I don't believe I got any coolant sucked into it (coolant level was down at the sticker), though I could be wrong. Also the chemical was unsealed right before the test, or did you mean age in general, sealed or unsealed?
Old 05-01-2011, 08:38 PM
Wow, you guys are fast!
rdunagan: Is being in the wet stage enough for the dealer to replace under warranty?
bismic: I'm using the motorcraft gold coolant @ 50% concentration. Flushed this past summer & installed new upper & lower hoses. No reason except I was working through the maintenance since purchasing it used. I've now installed the coolant filter and am on the 3rd filter, though after opening the first two I didn't notice much in it, at least nothing compared to what others have posted.
The dealer recently reflashed the modules for a smoking on start issue (didn't fix it). I'm using the motorcraft additive (antigel up to now) and I don't idle it much. I cleaned the EGR valve a month or so back and didn't look too bad this time. Is there a way to test if it is bad?
Old 05-01-2011, 08:55 PM
bismic's Avatar
I was hoping that if your coolant was VERY dilute, you would see some higher pressures. I hate to say it, but it sounds like head gaskets to me.
I do not know of a way to test the EGR valve. Is it the original? I forgot to mention that I changed mine out in 2008 because Ford had updated the design somewhat.
You said they did TSB 09-08-03 ......... did they leak check the EGR cooler out of the vehicle?
2015.5 Torque Pro PIDs Tugly 1999 - 2003 7.3L Power Stroke Diesel 126 08-11-2016 09:11 PM
Head gasket questions. I got so many variables, I can't keep anything straight. genscripter Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 10 06-08-2016 12:01 AM
testing for HG leaks- did I miss something. rossterman 6.0L Power Stroke Diesel 8 01-15-2016 08:36 PM
Please Help! Cooling system problem bigstakn Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 01-16-2014 04:49 PM
coolant testing Tanbeard 1999 to 2016 Super Duty 16 07-08-2013 12:43 AM
Tags
2003, 60, antifreeze, block, check, combustion, diesel, f350, ford, gasket, green, head, leak, ranger, turns, v6, yellow
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
