Newer rear axle - Ford Truck Enthusiasts Forums
Newer rear axle
Old 04-27-2011, 03:39 PM
Bovaloe's Avatar
Bovaloe Bovaloe is offline
Bovaloe is starting off with a positive reputation.
Newer rear axle
Would I be able to swap in a 8.8 out of a 97 and newer F150?
Is there a speed sensor in them like in the one I have? Spring and shock mounts same or different?
I'm looking at getting a LS and some better gears for my 88 f150 as cheap as possible.
Old 04-27-2011, 04:11 PM
thechief66's Avatar
thechief66 thechief66 is offline
thechief66 is gaining momentum as a positive member of FTE.thechief66 is gaining momentum as a positive member of FTE.
The 1st thing that comes to mind is that the wheel bolt pattern is different-you'd have to have 2 spare tires.
Old 04-27-2011, 05:10 PM
Bovaloe's Avatar
Quote:
Oh yeah, forgot about that part. Well I guess thats that then. Damn
Old 04-27-2011, 05:19 PM
Skinsfan6's Avatar
Skinsfan6 Skinsfan6 is offline
Skinsfan6 has a very good reputation on FTE.Skinsfan6 has a very good reputation on FTE.Skinsfan6 has a very good reputation on FTE.Skinsfan6 has a very good reputation on FTE.
Are axleshafts interchangeable between the two? That would allow you to keep the bolt pattern...
Convert to newer lug pattern? Cheggie 1987 - 1996 F150 & Larger F-Series Trucks 8 12-23-2011 09:54 PM
8.8 differential compatibility tpeck 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 09-16-2008 12:49 PM
8.8 differential fromme87 Clutch, Transmission, Differential, Axle & Transfer Case 3 03-01-2006 05:39 PM
New rear axle widths? boilerbots 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 07-22-2005 06:40 AM
9" swap satkins1044 Clutch, Transmission, Differential, Axle & Transfer Case 2 07-07-2003 04:44 AM
Tags
axle, courier, ford, rear, width
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
