Radiator cap question
The radiator I have is a stock(on the outside) 56 but I have it rebuilt with an additional row of tubes to help with the cooling. The radiator guy said to use a 4 pound pressure cap but since I am using a 351w engine my mechanic pals tell me that 4 lbs is not enough for this engine and that I need 12 lbs to keep the water in the radiator. The problem is that all the caps I can find which are the correct dimensions don't go over 4 lbs. I am sure someone has solved this problem before. Thanks for your help.
You need a better mechanic. Using a pressure cap on an old radiator is a good way to split seams, or other related damage. They weren't designed to be under 14lbs of stress. I had a 4lb cap on the stock 6 cyl. radiator I used with a 289, and I had no issues whatsoever. I don't know why anyone would tell you the SBF would blow the water out of the rad without higher pressure in the cooling system. That makes no sense at all.
52 USCG Panel
15
03-22-2016 08:24 PM
Tony Arneson
09-26-2014 02:32 PM
