97 F 250 Steering Column Issues - Ford Truck Enthusiasts Forums
Old 04-27-2011, 03:49 PM
aj197816134 aj197816134 is offline
aj197816134 is starting off with a positive reputation.
97 F-250 HD with Powerstroke, Auto, Cruise, Tilt
I am having the steering column blues, there is alot of play. I consider myself faily competent to replace bearings or bushing, but I am already seeing some metal shavings when I took the cover off. I cannot find a used column locally, and the one I found they want Arm, Legs, and FEET FOR...
My question is, IF i have a 93 F 150 can I use this column in my truck and add the cruise components etc or no?
Also any previous threads on the bearing replacement?
Tags
1997, 4x4, 97, column, f250, ford, freestyle, hd, huge, parts, problem, repair, shaft, steering, tilt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
