Steering Problems - Ford Truck Enthusiasts Forums
Steering Problems
Old 04-27-2011, 02:17 PM
daves302 daves302 is offline
daves302 is starting off with a positive reputation.
Steering Problems
Need some advice. 1990 F150 power steering, turns left easily, right hand turn is like manual steering. Truck has sat for about a year and I just recently put about a thousand miles on it with no problems. Then suddenly this steering problem. Any ideas? Thanks
Old 04-27-2011, 02:26 PM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
My guess would be that you have an internal fluid leak in the steering gearbox. However check that none of the tie rods or balljoints is binding.
Old 04-27-2011, 08:13 PM
Steering linkage components look OK, I will switch out gearbox before the weekend and let you know how it turns out. Thanks
Tags
1986, 1990, 96, binding, f100, f150, f250, ford, left, problem, problems, steering, sticks, turning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
