Truck/Trailer wiring all fugged up... - Ford Truck Enthusiasts Forums
Old 04-27-2011, 11:13 AM
SideWinder4.9l's Avatar
SideWinder4.9l SideWinder4.9l is offline
SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.
I got a neat little trailer yesterday, went straight to O' Reilly's, and bought a matching 4 pin/flat connector...
I THOUGHT it was going to be straightforward....But No.....
I can get either stop lamps and NO turnsignals....OR .....Turn signals and NO stop lamps....And I REALLY need both....
The tail lights on the trailer, has the standard 4'' lenses, and a have a smaller, 2" x 2" lens on the outer side....
The stoplamps have 3 wires in them-
White-Ground-It's already grounded to the trailer frame
Gray
Brown/Grayish
and the smaller lenses have just a single gray wire from it (It is on a common ground plate with the stop lamps)...
My question is, on the 4 pin connector (Trailer side) it has the following color coded wires
Black-Ground
Black w/ Green Stripe-Right Turn Signal
Black w/ Yellow Stripe-Left Turn Signal
Brown-Stop lamps
Do I wire the brown (Stoplamps) wire to each of the turn signal wires? Or will that short the system out?
All help is greatly appreciated....Reps WILL be sent for this.....
-Wes
Old 04-27-2011, 11:41 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Brown is the Marker lamps (running lights), not stop lights.
The turn wires are also the stop lamp wires.
Old 04-27-2011, 11:44 AM
I stand corrected....Will they function like the regular taillamps o a truck? Marker/Brakes/Turnsignals?
Thats what i am looking to get accomplished.....Is that how they are supposed to function?
Old 04-27-2011, 04:48 PM
subford's Avatar
Yes it is.
Do you need a diagram?
Here is one:
Old 04-27-2011, 04:51 PM
Jaime74656's Avatar
Jaime74656 Jaime74656 is offline
Jim
Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.
depending on your hitch type and trailer connector (assumeing standered 4 pin trailer) and your truck if its an RV hook up will either be a 6 pin or 7 pin (mine is 6 pin) you could go to your local Uhaul place and get the proper adapter for your hitch/trailer as I had a similar issue where I need to go from 6pin RV to 4 pin trailer.
Old 04-27-2011, 05:35 PM
Thanks for the diagram Bill....
I actually googled it, and now its fixed....
Need help with BOO switch Voltage wrenchhead428 1987 - 1996 F150 & Larger F-Series Trucks 0 10-16-2015 04:35 PM
4 pin trailer connection SEAL1 Explorer, Sport Trac, Mountaineer & Aviator 6 07-13-2015 06:30 PM
F150 turn lamp issue cherrybomb37 1987 - 1996 F150 & Larger F-Series Trucks 1 12-03-2014 12:44 PM
Trailer wiring colors stock from truck side?? 1fixitman 1999 - 2003 7.3L Power Stroke Diesel 2 01-07-2013 10:02 PM
trailer plug wiring question bigbubba87 1999 - 2003 7.3L Power Stroke Diesel 12 01-27-2009 09:39 AM
Tags
350, 96, camper, coachman, color, diagrams, f150, ford, international, pin, signal, stopturn, trailer, truck, turn, wires, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
