Idle speed 1991 F150 5.8 - Ford Truck Enthusiasts Forums
Old 04-27-2011, 07:03 AM
DBGrif91's Avatar
DBGrif91 DBGrif91 is offline
DBGrif91 is gaining momentum as a positive member of FTE.DBGrif91 is gaining momentum as a positive member of FTE.
I'm just curious to know what actually controls the idle speed? I understand that the TPS and IAC valve have effects on idle speed, but where is the actual value determined? Does the computer have a target RPM value?
Just wondering because my truck has idled low since I've owned it. The stock tach is reading about 350 RPM, which I know is too low for the engine to actually stay running- but it's certainly not idling @ 1000 RPM, as I hear most of you guys talk that it should be. I would guess it's running at 500-600 RPM but obviously I don't know for sure. To my knowledge there are no vacuum leaks.
I'm looking to increase the idle speed and want to know what I need to look at to make this happen. Just FYI, but the IAC and TPS are both less than a year old, and the TPS is reading 0.9v.
Thanks.
Old 04-27-2011, 08:35 AM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
You need a more accurate tachometer. There is no way to "adjust" the idle speed without having a custom chip or tuner. The idle speed is controlled by the PCM. It uses various input signals to derive the target idle RPM. IIRC the target idle speed in drive is in the 650-700 RPM range for my 5.8L engine. In neutral or park my tach reads about 900 RPM when the engine is warmed up.
Old 04-27-2011, 09:45 AM
DBGrif91's Avatar
Fair enough- what all affects idle speed then? All the sensors or only a few? Again, I get the TPS would, but what about the MAP sensor or maybe the ACT?
Just to provide more info, the only code I'm trying to work out right now is 213 [SPOUT circuit open] which is triggered in KOER. But this code wasn't triggered until recently so I don't think it's related to the issue.
Is the coil the only thing the tach feeds off of, or what other connections should I check?
Old 04-27-2011, 09:53 AM
rla2005's Avatar
The factory tach is known to be less than accurate. The signal comes from the negative side of the coil. Ryan has a good write-up of the different modes the computer works in. Look at the section under Warm Idle: Ford Fuel Injection Strategies
Code 213 could be a contributor if the circuit is not allowing the PCM to control the timing. With the SPOUT in and out can you see the timing change with a timing light?
Old 04-27-2011, 04:45 PM
DBGrif91's Avatar
Thanks for the info- I'll get back to you when I know.
High Idle and high IAC voltage issue dstrahm Aerostar 6 11-19-2016 11:33 PM
Very slow low idle when warmed up TwoMuchMud Escape & Escape Hybrid 17 07-30-2016 09:10 AM
High Idle 1999 5.4, now no electric Shernius 1997 - 2003 F150 9 06-13-2014 10:14 PM
1990 EFI 5.8l, idle speed, fast idle, sensors and hacking teh system ErrorS Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 0 06-23-2012 02:33 PM
Throttle setup question hoss khaos 1987 - 1996 F150 & Larger F-Series Trucks 15 08-27-2011 09:52 PM
Tags
1987, 1991, 351, 58, adjust, air, f150, ford, idle, motor, power, rpm, spec, speed, time, truck, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
