Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-21-2003, 12:28 AM
Alex03 is starting off with a positive reputation.
Clicking sound when I turn key
Whenever I turn the key to start my 390 all i hear is a clicking sound. I put in a new starter and that didn't help. I tryed jumping it across the solenoid and all it did was spark and got hot? Does anyone know what the problem is?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-21-2003, 06:32 AM
macguyver is starting off with a positive reputation.
Can you turn the engine over by hand?
__________________
'77 F-250 Camper Special 400ci driver
'76 F-250 Supercab 360ci current project
'71 Mach I 429CJ in storage
'79 F-150 for parts
huct on foniks wurkt fer me
  #3 (permalink)
Old 03-21-2003, 09:39 AM
Yeah I guess I could. Its a manual so I could just pull it. What would that help?
  #4 (permalink)
Old 03-21-2003, 09:43 AM
When it started acting up I was testing my compression and had the wire that goes from the distributor to the coil disconnected and I went to turn the engine over and it was still in gear. When I stopped to take it out of gear and went to try it again all I heard was a click. Im Stumped
  #5 (permalink)
Old 03-21-2003, 11:04 AM
I was just wondering if the engine was stuck or if the starter wasn't working (bad cable, starter, weak battery etc.)
BTW As long as you have all the plugs out for the compression test, the engine shouldn't be hard to turn over with a socket on the crank pulley or even by turning the fan.
__________________
'79 F-150 for parts
  #6 (permalink)
Old 03-21-2003, 02:07 PM
Mil1ion is starting off with a positive reputation.
How long has the engine been sitting without being run?
Sometimes starters seize up a little after sitting a while
(enough though you had it turning briefly).
How good is the battery ?
  #7 (permalink)
Old 03-21-2003, 02:18 PM
jimlj is gaining momentum as a positive member of FTE.jimlj is gaining momentum as a positive member of FTE.
Do you have a dead or weak battery? Sounds like you may have run the battery dead while doing your compression test.
  #8 (permalink)
Old 03-21-2003, 08:03 PM
daddyswheels is starting off with a positive reputation.
Hey buddy! Make sure you check the battery posts and lugs to make sure they are clean and then the lugs tight, If you don't do this once a year on an older vehicle, a small occlusion zone of galvanic do-do forms between the two pieces of metal from the exchange of electrons passing thru and other good stuff out of the atmosphere bonding in there with it and can actually cause a resistive barrier and not let the juice thru in the way you want, it also causes your battery to not fully charge. Clean your terminals and put the battery on the 8 hr 2amp trickle charge (solid link!) I think you will be pleased...the clicking is the solinoid not getting enough juice!
__________________
jc
  #9 (permalink)
Old 03-23-2003, 04:01 PM
I found the problem. It was the sloenoid to starter cable. I changed that and it fixed everything. After I bought a new starter for no reason
  #10 (permalink)
Old 03-24-2003, 01:36 AM
Torque1st's Avatar
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
If you buy a manual there a checks that you can perform with a voltmeter to isolate the problem b4 you spend big buck$.
__________________
"Beam me up Scotty. There's no intelligent life down here..."
Eric
Tips & Tricks FAQ for 335 Series Motors
73-79 FAQ & Info
Garage Forum FAQ
For more info use PM.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
