2011 6.7L Powerstroke and ScanGauge II XGAUGE codes - Ford Truck Enthusiasts Forums
Old 04-26-2011, 09:44 PM
swengle's Avatar
swengle swengle is offline
swengle is starting off with a positive reputation.
I spent part of the weekend playing around with my Linear Logic ScanGauge II plugged into my 2011 Job 2 F350 w/ the 6.7L Powerstroke. I had spent some time researching XGAUGE codes – I had a stack of print outs for “generic” codes and codes specific to the 7.2, 6.0, and 6.4 liter Powerstrokes. Of all the ones I tried, these are the only ones that worked.
Below confirmed to work on 2011 6.7L Powerstroke
Horse Power (Diesel Gross/Brake, as a percentage)
TXD:
00
RXF:
400080000000
RXD:
0000
MTH:
000A00240000
NAM:
HPR
Note: Assuming HP is reported as a percentage at it topped out at 108 when I floored it 0 to 60.
Fuel Level (as a percentage)
TXD: 07DF012F
RXF: 0441052F
RXD: 2808
MTH: 006400FF0000
NAM: FLV
Barometric Pressure (in PSI)
TXD: 07DF0133
RXF: 04418533
RXD: 2808
MTH: 006400450000
NAM: BAR
Below confirmed to NOT work on 2011 6.7L Powerstroke
FICM Main Power (Volts)
TXD: 07E02209D0
RXF: 0462450906D0
RXD: 3010
MTH: 0064010000000
NAM: FMP
Manifold Absolute Pressure (in PSI)
TXD: 07E0221440
RXF: 046285140640
RXD: 3010
MTH: 012203200000
NAM: PSI
Torque into torque converter (in ft-lbs)
TXD: 07E022163A
RXF: 04620516063A
RXD: 3008
MTH: 000200010000
NAM: CTQ
Alt Torque into torque converter (in ft-lbs)
TXD: 07E122163A
RXF: 04620516063A
RXD: 3008
MTH: 000200010000
NAM: CTQ
Cylinder Head Temperature (in Degrees F)
TXD: 07E0221624
RXF: 046205160624
RXD: 3010
MTH: 000200010000
NAM: CHT
To get the really interesting stuff I guess I have to wait for Autoenginuity to deliver an Enhanced Ford Expansion package that supports the 6.7L Powerstroke. I emailed them about this, response was it would be available toward the end of 2011.
Steve
Old 04-27-2011, 12:06 PM
rcorcich's Avatar
rcorcich rcorcich is offline
rcorcich is starting off with a positive reputation.
I'm interested too.
Subscribing
Rich
Old 03-05-2013, 05:47 PM
2012F250SUPERDUTY4X4's Avatar
2012F250SUPERDUTY4X4 2012F250SUPERDUTY4X4 is offline
2012F250SUPERDUTY4X4 is gaining momentum as a positive member of FTE.
Subbed also..
I been looking for a way to monitor everything in one simple package.
Scangauge II XGauge Codes for Misfire Monitor cornfarmer1 Modular V10 (6.8l) 1 05-09-2016 09:32 AM
Some Sc II codes for "Xgauge" (Now injectors) amdriven2liv 6.0L Power Stroke Diesel 251 05-30-2015 04:05 AM
No EGR Duty Cycle reading with ScanGauge II ajg617 6.0L Power Stroke Diesel 3 09-28-2014 08:22 PM
VGT readings on scangauge j4henry 6.0L Power Stroke Diesel 22 04-17-2012 09:51 PM
Transmission Gear Reading ScanGauge fixxxer-upper 6.0L Power Stroke Diesel 4 12-13-2011 06:52 PM
Tags
2011, 64l, 67, 67l, 73, codes, escape, f250, ford, gauge, powerstroke, pressure, scangauge, turbo, working, xgauge
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
