whats a T8D 1A trans for? - Ford Truck Enthusiasts Forums
Old 04-26-2011, 09:52 PM
thundersnow70's Avatar
thundersnow70 thundersnow70 is offline
thundersnow70 is starting off with a positive reputation.
my son talked me into dragging the trans out of the corner the other day. i am not sure how i came to own it. i either got it with the flathead i bought for the mh years ago, i think it came out of a f1 monkey face, or i got it with the 52 f3 mh when i drug all three loads of that truck home. it just dawned on me i should go lay under the f3 and see if the trans are the same, but i have typed this far so im just gonna push the submit button. thanks all
Old 04-27-2011, 12:44 AM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
T 8 D or T87D??
T87D is the heavy duty 3 spd with synchro 2 and 3. Heavy and bullet proof.
Old 04-27-2011, 02:43 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
F1 Borg Warner T-87D: A8C-7001-A / Case marked 3D / 1948/56 Ford truck parts catalog sez: H/D, lip of clutch housing has two cut-outs.
F2/F5 Borg Warner T-87D: 8J-7001-B / No case marking listed, nothing mentioned about clutch housing.
T-87's will also be found in 1953/66 F350's and were an option for like years F250's.
Old 04-27-2011, 09:36 PM
i can see that the son is gonna have to get to cleaning some more crud off to make sure we get the right numbers. that should keep him out of trouble tomorrow. thanks guys
Old 06-21-2011, 05:06 PM
havi's Avatar
havi havi is offline
I'll have the Roast Duck
havi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to all
T8 D -1A is the crashbox 4sp.
Old 06-21-2011, 07:16 PM
38 coupe's Avatar
38 coupe 38 coupe is offline
38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.
The crashbox is a T9. I have not seen one labeled T8.
Old 06-21-2011, 07:48 PM
havi's Avatar
I typed in T9 in google, and it comes up with a light duty 5sp. for the Ford Capri, lol. BUt you're not that far off, as on Van Pelt's website, he refers to the 4sp. as a T8 ( http://www.vanpeltsales.com/FH_web/t...ruck4speed.htm ), but in his parts/price listing he labels it T8/T9. ( http://www.vanpeltsales.com/VPPSweb/VPPS-homepg.htm )
Old 06-21-2011, 08:13 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle Jeff and Nicolle is offline
Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.
Everyone likes pictures! From my 49 F3 4 speed crashbox
Old 06-22-2011, 01:45 AM
Thanks for the info - I've always called that a T9. I'll have to look closer at my 4 spd grinders......
Old 06-22-2011, 07:48 PM
38 coupe's Avatar
Thanks for the picture. Now I need to go look at my parts transmissions...
Old 06-22-2011, 08:21 PM
truckdog62563's Avatar
truckdog62563 truckdog62563 is offline
truckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud of
The case markings on Jeff's case are exactly like the markings on my crash box 4 speed from my 52 F-3 MH and on the one I parted out a short time ago. Stu
Old 06-27-2011, 08:17 PM
boy Havi, you dug this thread back up. thanks for the insight. so i guess its just a 4 speed crashbox. good to know, should work in the rest of my junk if i need it.
Old 09-30-2011, 04:14 PM
bradblf2 bradblf2 is offline
bradblf2 is starting off with a positive reputation.
1950 ford pickup transmission
Looking for any info on the transmission in my ford
T8 D-1A WG-CO 4
Old 09-30-2011, 04:59 PM
Brad, I just left you a visitor message.
1966 F600 MH questions cmo Large Truck 14 08-21-2016 12:26 AM
52 F2 rear leaf spring pin keepers? thundersnow70 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 10-27-2015 08:17 PM
Mercury M6 VIN decode help CaptPayne 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 04-08-2015 02:09 PM
badges rons 56 mh 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 08-16-2014 08:14 PM
1938 COE 101" wheelbase with Marmon Herrington jmadsen 1947 and Older Ford Trucks 27 10-19-2012 01:11 PM
Tags
1949, 8d, borg, ford, speed, t, t8, t8d, t8d1a, t8dia, trans, transmission, truck, warner, wg
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
