A friend of mine has a 2002 F-250, 7.3L, 2WD, crew cab. His truck is show the doors are ajar when closed and showing closed when the doors are ajar. He pulled the sensors from the doors and and manually checked them. Pushing down on the the sensor they work correctly and all, but when put back into place the don't work properly again. What could be the problem, any ideas?
Liberally (but not too liberally) spray the latch and assembly with WD-40. Wipe up the excess, open and close the door a few times, should take car of the issue. It's worked on my F150 and my Mustang.
Just realized you wrote 'doors'... plural... odd that numerous sensors would go at the same time. Possible grounding issue is my guess, especially if they are reading backwards.
The sensors are part of the door latch assembly. Spray the latches with WD 40 or Silicone lubricant. If you have the extended cab, remember there is a latch on top and bottom of the extended cab doors.
Hi, I know it's been a while but did you ever find a solution to your backward reading sensor problem, I'm having the same issue in my 02 7.3l f350?
WD40 did the trick! Spray a liberal amount then open and close the door repeatedly. You might have to do this sequence more than once. But that foxed mine.
