More fan blades?
Another route is to put an electric fan on the front of the radiator, you can get them with an adjustable thermostat switch, so the fan will come on at a preset temp. I did that and I never get over 185, it usually runs at about 160-165, and it will go up to 185 in heavy So. Cal. Traffic. You can get the fan and switch at most auto parts for around $100 or you can go for a bigger fan set up ( 2800 CFM) for about $150-185 and remove your current fan completely. It is up to you! That is just another option. I put a remote switch in the cab so I can turn it on manually if I choose such as when I hit a big grade towing the trailer. Some people don't like the electric fans, but all of your new cars use only the electric fans, as they free up horsepower!
Depending on the applications, these fans used w/fan clutches will be: 18 1/2" or 19" or 19 1/2" diameter. Some are flex-fans, some of which have massive blades that are very noisy when the fan isn't free wheeling.
1965/67 F100/250 352: The original 4, 5 and 6 (6 = used w/dealer installed A/C) bladed fans were 18 1/2" diameter, none used a fan clutch.
1975/80 Granada 200/250 I-6 6 & 7 bladed fans used wth A/C are the correct diameter, do not use a fan clutch.
There are other similar 6 & 7 bladed fans used in mid-sized 1965/79 I-6 & V8 Passenger Cars that will also work that did not use a fan clutch.
In 1982 when I did a "frame-off" resto on my (now former) 1965 F100 352, I installed a 4 row radiator, fan shroud from a 1968/76 F100/350 360/390 w/o Super Cooling radiator (it bolted right on w/o mods), and then...
Took the original 4 bladed fan, went thru boxes of new fans to match up the diameter and to add blades. That's why I know the 7 blade Granada fan will work, cuz that's what I used.
I wouldn't recommend getting rid of the mechanic fan even if you added the electric also due to where you live. It won't flow enough.
All of these will have a 2 3/8" center hole, used for a viscous drive fan clutch. Similar 7 bladed fans will be found in 1965/78: Galaxie/LTD, full sized Mercs / 1964/79 Thunderbirds / 1969/79 Continental Mark III, IV & V's.
medctr1
05-11-2016 12:26 AM
MyDads64
09-10-2004 03:55 PM
