95 F150 4x4 front spindle/axle/seals/thrust washer/bearings? - Ford Truck Enthusiasts Forums
Old 04-26-2011, 03:36 PM
jmczzz jmczzz is offline
jmczzz is starting off with a positive reputation.
The parts houses don't seem to have a thrust washer that goes on the spindle after the outer wheel bearing. Does any one know where to get one or a substitute?
Also the seal for the spindle needle bearing does not come with the bearing. I found one at Rock Auto parts, but wonder how necessary this seal is?
Old 04-27-2011, 08:36 PM
Ohio Ford Farm's Avatar
Ohio Ford Farm Ohio Ford Farm is offline
Ohio Ford Farm is gaining momentum as a positive member of FTE.Ohio Ford Farm is gaining momentum as a positive member of FTE.
If the parts place does not have the washer go to your dealer
AS for the little $2 spindle bearing seal. I have yet to see one stay in place ... ever! I just pack a crap load of grease in there to try to help keep water out.
Old 04-27-2011, 10:53 PM
gees, I paid 6 bucks for the 2 $ seal ...
that never stays in place.
I did pack a crap load of grease in there also so maby I'm good for a while.
Also I changed the sequance of the lock nuts and lock washer. Used the lock washer first in place of the thrust washer, then both nuts. I live in the Ozark Mtn boonies and am following the weather service instructions to watch for a tornado (haven't seen one yet). I'll take a trip into town when it they tell me I can stop watching, and see if the dealer has more than the current year washer in stock...
thanks, JIm
D60 Thrust washer required? Royson12 6.0L Power Stroke Diesel 20 10-06-2016 05:52 PM
90 B2 Dana 28 parts needed 2trux WTB - Parts & other 0 11-01-2015 01:41 AM
Dana 44 solid axle question rchalmers3 1973 - 1979 F-100 & Larger F-Series Trucks 0 09-16-2014 02:11 PM
thrust washer jaroh Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 04-16-2013 01:43 PM
King Pin Help, 71 f100 with disc conversion shift1313 1967 - 1972 F-100 & Larger F-Series Trucks 9 02-16-2009 01:21 PM
Tags
2000, 4x4, 99, bearing, caps, duty, f150, f250, ford, front, seal, spindle, super, truck, video, x4
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
