Dirty fuel tank ?
Old 04-26-2011, 01:52 PM
hotweekend's Avatar
hotweekend
hotweekend is offline
Unhappy Dirty fuel tank ?
Hi, did you see this? I clean these filters couple times in the last year in order to keep the engine running, but I never see that grey or silver scalps on the fuel tank filters. Looks like the the paint or tratment inside the tank is peeling.
Old 04-26-2011, 01:59 PM
onelionhunter's Avatar
onelionhunter
onelionhunter is offline
wow
Wow, that is ugly. Can't beleive it is that dirty again after a recent cleaning, wonder what is failing, or if somewhere you are getting fuel has a tank with its lining coming apart?
Old 04-26-2011, 03:04 PM
clintbonnie's Avatar
clintbonnie
clintbonnie is offline
Is this an aftermarket external fuel filter, before the fuel pump ?
Old 04-26-2011, 03:10 PM
hotweekend's Avatar
hotweekend
no, that's the filter inside the gas tank
Old 04-26-2011, 03:19 PM
dn29626's Avatar
dn29626
dn29626 is offline
You need to do the Hutch mod. This is a good idea of what is involved.
Welcome to guzzle's In-tank Hutch Mod Web Page
Old 04-26-2011, 04:25 PM
429 f-100's Avatar
429 f-100
429 f-100 is offline
when i did the in tank mods it was the rod that the flote was on that was corroding but you had to buy the whole sending unit so i sanded it and went on. get rid of those filters and the whole mixer valve.
Old 04-26-2011, 06:13 PM
danskool's Avatar
danskool
danskool is offline
Go Bills !
Agree, It can't be your equipment. I would notify the fuel station of this. Show em these pictures. How do you tell what station it is could be tricky. I don't stick to one station.
Even though you should get rid of those filters, with debri like that you should put in a inline filter to protect the pump. Plus the pick up screen will soon be clogged anyways.
That gunk don't look like anything we have in the tank. Unless it is paint chips from the filling neck. But don't look like rust
Old 04-27-2011, 11:17 AM
429 f-100's Avatar
429 f-100
yea i kinda agree with dan mine were smaller pieces and were rust those dont look like what was cloging mine which was coming off the rod.
Old 04-27-2011, 10:36 PM
hotweekend's Avatar
hotweekend
I don't use the same Gas Satation everytime so I don't know what to think. Plus, I clean the filters with the same scenario couple times this past year (3 or 4 times).
Did somebody hear about Gas tank peeling in our Ford trucks? It seems to be a common issue :-(
Old 04-29-2011, 07:14 AM
429 f-100's Avatar
429 f-100
my tank looked brand new inside at 12 years and 264000 miles.
Old 04-29-2011, 08:33 AM
clux's Avatar
clux
clux is offline
The F-450's have a steel tank with a plastic liner. I'd guess yours is coming apart.
Old 04-29-2011, 10:39 AM
clintbonnie
I think Clux has the problem solved.. I found this on the net... it is a 2005 F450, but the steel tank has problem with delamination.
Corrosion in Ford diesel fuel tanks (p.2)
Old 04-29-2011, 05:58 PM
danskool's Avatar
danskool
danskool is offline
Go Bills !
Good info Clux..
Old 04-29-2011, 07:41 PM
clux's Avatar
clux
clux is offline
Just a little nugget of knowledge I picked up at the Ford forum I frequent......................
Old 02-28-2013, 05:17 PM
matt9923's Avatar
matt9923
matt9923 is offline
was this modified at some point? it is not like any of the others i have seen
2001 f450 7.3
Quick Reply: Dirty fuel tank ?
