Bleeding Fuel Line - Ford Truck Enthusiasts Forums
Bleeding Fuel Line
Old 04-26-2011, 12:29 PM
sifox sifox is offline
sifox is starting off with a positive reputation.
Bleeding Fuel Line
1994 ford f250 7.3l turbo diesel.
I just changed one of the fuel lines that goes to the injector. Now my truck is not running the same. I would like to know how to bleed the fuel lines.
Thanks in adavance.
Old 04-26-2011, 12:51 PM
snaponprofile's Avatar
snaponprofile snaponprofile is offline
snaponprofile is starting off with a positive reputation.
If you are reffering to a metal line, simply loosen the line at the ingector and crank until diesel comes out, then tighten the line and start it.
Old 04-26-2011, 07:48 PM
tecgod13 tecgod13 is online now
tecgod13 is gaining momentum as a positive member of FTE.tecgod13 is gaining momentum as a positive member of FTE.
It should bleed out by itself, especially if you only changed the one line. If its not bled out after driving around for a few minutes, something is wrong.
Is there anything else wrong? Why did you replace the line?
Old 04-26-2011, 08:00 PM
Did you put the line clamps back on?
Old 04-26-2011, 08:13 PM
91dirtydiesel's Avatar
91dirtydiesel 91dirtydiesel is offline
91dirtydiesel is gaining momentum as a positive member of FTE.
Does it matter if clamps go back on The metal line?
Old 04-26-2011, 08:15 PM
Yes, If not, the metal lines will eventually crack as a result of the vibration.
Old 04-26-2011, 08:32 PM
Well I better put mine back on then haha
Old 04-26-2011, 09:02 PM
Yep, most take em' off to paint the lines and never put them back on, lol.
Old 04-26-2011, 09:51 PM
Exactly what I did
Old 04-27-2011, 01:37 AM
Yeah, I think I got some other problem. I replaced the line because it broke when I was driving. I did put the clamps back on. I drove my truck to work, 10 hours laters I had problems starting it. After starts it's easy to start it again. The problem is when it seats. I check all the lines and I don't see a leak. I'm planing to change the fuel filter tomorrow and look for leaks.
Old 04-27-2011, 04:31 PM
Sounds like an air leak into the return lines. It may not show as a fuel leak, but the air will leak in and the fuel will siphon back to the tank causing hard starts.
My guess is you need to do a return line kit, or at least replace the o-rings if the plastic caps and fuel lines look fine. size #111 viton rings. There are PLENTY of threads discussing return lines....
Old 04-27-2011, 04:50 PM
Saying your truck wasn't 'running the same' identifies rough idling/lack of power. It sounds like it runs fine once you get it started so the problem is know as hard starting.
Old 04-27-2011, 06:04 PM
Thanks, The kit should be here some time tomorrow. Hopefully that soles my starting problem.
Old 04-27-2011, 11:51 PM
ManicMike's Avatar
ManicMike ManicMike is offline
ManicMike is starting off with a positive reputation.
Quote:
You more then likely knocked a return line loose. They become brittle after a while and if you move them they'll leak.
A quick tip to see if the return lines are leaking at all: Park the truck, let it sit overnight, slowly pull the fuel filter off the next morning, IF IT'S NOT FULL to the brim with fuel, you have a leak.
Old 05-04-2011, 12:44 PM
I finally had time to replace the return lines and seals. Now the truck starts normal. The only problem I have is that it's throwing tons of smoke, white smoke. That wasn't like that before. What do you guys think I did wrong to make that happen? When I come to a complete stop the engine sounds like is having trouble getting fuel.
bleeding fuel lines after new tank install BrotherGotaFord Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 15 08-03-2013 10:57 AM
Bleeding Fuel Line patshea814 1999 - 2003 7.3L Power Stroke Diesel 3 02-08-2011 09:23 AM
bleeding air from fuel lines on 6.9 DNewton Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 03-04-2007 07:36 PM
fuel line bleeding captjohn Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 08-27-2004 07:37 PM
How to bleed fuel line seanster76 Explorer, Sport Trac, Mountaineer & Aviator 2 07-03-2004 11:55 PM
Tags
1997, 69, 73, bleading, bleed, bleeder, diesel, ford, fuel, fuelsystem, idi, injectors, line, lines, liter
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
