Really bad gas mileage on 302
#46
That's not possible.. with larger tires the truck travels further so if nothing else changed(it never does but for the sake of simplicity in this example) your milage should have increased with the bigger tires. Bottom line is you aren't calculating fuel milage correctly and the main device used to calculate milage(the odometer) is no longer accurate, so you need to recalibrate your speedo for those tires and then divide the distrance travelled between fillups(using the trip meter) by the gallons needed to refill the tank, that is your MPG. Do this at every fillup and you'll get a average of what milage the vehicle really gets over various conditions and driving styles.
I have done that i do that everytime i fill up and thats what it gets 8 mpg
#48
#49
#50
HELP PLEASE!!!!!!
I have recently received a free 79 ford f150 ranger 2wd, Ive been cleaning it up and did some things to the motor. It previously sat in a garage for 25 yeas and i have done water pump, plugs, freeze plugs, radiator, oil, hoses, etc. I have the original 302 and 2 barrel carb and it isn't very good on gas. I have ran sea foam through it and it made it runs bit better. Im looking to improve the MPG because it isn't good at all, maybe change the carb and intake or rebuild the old 2 barrel? Thanks
#51
Fustrated
My truck is a 1996 f150 4x4. And im getting 8.4 miles per gal granted ive got 31.10'50s mudtires on it and I have a wooden box I haul trash but I went from 14 to 8.4 miles in the last 5 months and ive been hauling for over ayr and a half help me fix it ive changed wires plugs cab ritor button fuel filter air filter map sensor one o2senser new exhaust.radiator...
#52
#53
#55
__ economy
Take off all the smog pump crap, bean cans, char filter box, and the EGR, and the fuel trim thermactor air bypass valve and regulator, leave all those electric connectors in place and cover with tape in case it doesnt help or you decide to sell the vehichle you add parts back on and have more original value. Cap all vacuum ports with vacuum line caps. Or duct tape.. leave the fuel pressure regulator vacuum line attached, or don't. I took it off and have put it back on, really don't notice a difference. I have oem style exhaust manifolds, 3 inch from collectors to rear axel, a 3 inch glass pack into a 2.5 over the axel. I have found an increase in fuel economy with this set up. Always having heard true dual exhaust with long tube headers is best for fuel efficiency. Maybe you should add a high air flow filter, or cold air intake? Maybe dual high flow/cold air. Biggest thing also, is if you're anything like me, don't try and race all the idiots that are jealous you're in a truck thats paid for and will last 100000000 miles, and they are in debt with a brand new everything in life, including a new truck that is designed to fail just after its out of anyone else's hands and fully into thine own hands. so if a heavy foot, proving to everyone what was built then squashes what they build now. Just act like you're in the year the truck was made. In the 90s the road was for commute, especially in town. I don't know that's my input
#56
#57
If you're in an area where emmisions arent regulated like the flow of immigrants currently...
Pulling the manifold reference line off the fuel pressure regulator is a bad idea. That will result in a variable delta across the injectors. The FPR is there to maintain the 39.15 psi delta across the injectors no matter the manifold vacuum.
The stock air intake IS a cold air intake.
Exhaust backpressure will always hinder performance on a 4-stroke ICE. Backpressure doesn't equal velocity or scavenging.
Thanks for the reminder that these forums exist. I'll have to tool around and see what's new.
The following users liked this post:
splitmaster
15
03-31-2003 05:18 PM
sitlet
09-18-2002 07:39 AM
