Leaking intake manifold
Old 04-26-2011, 10:44 AM
johnson2007's Avatar
johnson2007
johnson2007 is offline
If I have an oil leak coming out of the ends of my intake manifold, will that also be a vacuum leak?
Old 04-26-2011, 12:15 PM
Justin's Green Truck's Avatar
Justin's Green Truck is offline
You mean where the intake mates to the cylinder head? Its possible I guess. If the intake gasket was bad it definately causes a vacuum leak, but I wouldnt think too much oil should be coming out of there if that was the only problem. Its not the valve cover leaking instead is it? Do you have any pics of it? Which engine do you have?
Old 04-26-2011, 12:30 PM
johnson2007
Its on a 400 and the leak isn't around the cylinder heads.It's at the ends of the intake manifold where it just sits on the block. I have puddles of oil around the sending unit in the back and the distributor up front and I can see a chunk of the rubber seal sticking out so I know that's where it is coming from. I am just trying to decide if I can put some RTV on it it or if I need to pull the whole manifold and do it again.
Old 04-26-2011, 12:35 PM
pumpdriver20's Avatar
pumpdriver20
pumpdriver20 is offline
I've got the same problem and keep putting it off as it looks like it's been doing it for years (I just got the truck). To do it right you need to pull the manifold and put down a new gasket.
Old 04-26-2011, 12:40 PM
Oh sorry I gotcha now. Yea mine does the same thing apparently its pretty common. On mine it doesnt cause a vacuum leak though. If you go to fix it, i would go the extra step and take the manifold off and reseal it.
Old 04-26-2011, 01:04 PM
704 dentside man's Avatar
704 dentside man
704 dentside man is offline
Those ends seals need a heavy dose of RTV black to stay in place.
Old 04-26-2011, 01:06 PM
johnson2007
Another question I have is, when I bought my edelbrock aluminum performer intake manifold, the instructions said not to use the metal valley pan gasket. Anyone had problems with using the valley pan gasket?
Old 04-26-2011, 01:21 PM
704 dentside man
^^^That's all I use. Helps repel a little bit of heat, and in my experience it's hit or miss as to whether I'll get a good long seal without one.
tommylg
13
02-16-2017 09:23 PM
RageOfAntioch
05-15-2016 09:36 AM
Alex_90
05-04-2016 09:25 PM
robjs111
02-23-2011 09:56 AM
ferryj1
11-10-2004 07:29 AM
Quick Reply: Leaking intake manifold
