2008 F350 Powestroke Blowed Up
2-12-2011 I Purchased 2008 F350 6.4 Powerstroke with 37028 miles on it, on March 29 2011 with 37779 miles on it, it BLEW UP, #2 cyl No Compression, after being at the dealership I purchased it from for a month, yesterday finally heard How Ford want's to fix it, A block, with the only component being a "2 piston rod assy. Isn't this a bunch of crap, I am not at all happy with Ford or the dealership. What do you all think about this crap.
I agree with Lakedweller, I think they will do it right mainly because they are going to have to stand behind it for at least a little while. They won't want to do another costly repair on their dime to save a few hundred bucks.
Bottom line is if they take it apart and see bearing problems on the crank, they will either machine or replace the crank as well. But at the same time they aren't going to replace 7 good pistons and rods if they are still in good shape.
One question I have is when it "blew up", did it just shutoff or continue to spin? The "just shutoff" version would tell me that the damage is isolated and you really have very little to worry about with metal being thrown all over and damaging other parts. The "continue to spin" version would mean that it's a crap shoot as to whether it stayed isolated to Piston #2 or you experienced collateral damage from the primary problem.
I'm interested to see how this works out for you. Please keep us informed if you get it fixed to your satisfaction.
Ford will fix it right and you will be happy. They do not intend to short change you. The dealer pretty much not in control of warranty Ford tells them what to do. If you can convince Ford they will pass it down to the dealer. As soon as the dealer pulled the engine and determined the damage they go to Ford for what is needed to do a proper repair. I know this is frustrating but they will get it right. I can assure you that if the dealer did not go to bat for you Ford would gone down the path they wanted, but your truck would have been right...
!!! JACKPOT !!! Ding ding ding!!!
Sounds like you won a pretty good deal. Like was said earier, I bet if there is any damage on the heads you will get it/them replaced. The injectors are a big bonus!!! I don't know anything about the 6.4L, but it sounds like maybe they feel like the injectors you have could have caused the problem in the first place. Either way, you've got a fairly fresh motor. Don't forget to drive it break-in style for a little while.
Blowed up
Thanks for your reply, back when I bought in February, I also bought an extended powertrain warranty 5yr another 60,000 ontop of what warranty was left, so the truck has close to 100,000 mile powertrain warranty, Thats what made me so Mad, the 2008 I bought 2 mos ago, has more warranty than any vehicle on this dealers lot.
Tony1790
1999 to 2016 Super Duty
110
10-09-2011 10:24 PM
