how to make a cold air intake??
Old 04-26-2011, 02:29 AM
ryito1122334455's Avatar
ryito1122334455
ryito1122334455 is offline
hi i have a 1992 f150 2wd straight 6 auto 107,000 miles. just got the truck in january for 900!!! love my green been. i would post pics but dont know how to do it on here. anyway id love to know how to make a cold air intake for my truck. has duel hoses from the box....id love to see some pics of everyones aftermarket homeade cold air intakes. also i have a squeeling sound after inital warm up, only at a red light, or when im not accelerating. wondering if its a belt or pully?? any advice or imput on my rusty ohio gem would be appreciated!!! and info on bodywork....im rusting REAL bad thanks
Old 04-26-2011, 02:43 AM
mean green 91's Avatar
mean green 91
mean green 91 is offline
to post pics you can go to photobucket.com and post your pics there. then copy the the url for the photo and paste it in the text field when you're posting.
dont ya love a good running truck for under $1000. a buddy of mine has a theory that any vehicle that runs and will pass inspection is automatically worth $1000 no matter what kind it is. i guess that is assuming it stays running.
cant help ya with the cold air.
Old 04-26-2011, 02:47 AM
ryito1122334455
as anyone can see..my green bean is rotting away (love ohio winters and cruel salt)......after i get the bugs worked out, id like to do the bodywork....dont know how or how much its gonna cost but id like to make her look represintable......cold air intake ideas anyone?
Old 04-26-2011, 03:25 AM
cjben's Avatar
cjben
cjben is offline
here is the best home built one I have seen. https://www.ford-trucks.com/forums/6...and-cheap.html
Old 04-26-2011, 10:57 AM
ChristopherN's Avatar
ChristopherN
ChristopherN is offline
I don't have a picture right now as going outside of work and taking a picture of your truck's engine bay is kind of weird.
But my truck has that plastic tube that mounts to the edge of the grill removed as well as the stock airbox. The stock hoses are all the same. It has a K&N #RF1012 filter that I believe goes with a custom mounting plate to hold it up.
I'll try and remember to take pictures after work.
Old 04-26-2011, 04:42 PM
ryito1122334455
anyone else have any ideas or suggestions? pics maybe? thanks everyone
Old 04-26-2011, 10:01 PM
skyfox10's Avatar
skyfox10
skyfox10 is offline
The stock setup for that truck is actually very good. Us SBF (302/351) guys go to junk yards to get the stock 300 setup for our trucks. The stock setup would get you much more cold air than the RF-1012 (pictured below).
I had one of those and other than costing a lot of money, it pulled it warm air and let in more dirt. (my current setup pulls in dirt, but the air is cooler than that old setup)
The link posted ealier is a great idea. Here is another idea.
https://www.ford-trucks.com/forums/9...-cold-air.html
Old 04-29-2011, 02:50 AM
ryito1122334455
Question
could i put duel cones at the end of both tubes? or should i use a y pipe to put 1 cone at the end? i would lie the most airflow possibe and to get the most outta my straight 6
Old 04-29-2011, 09:25 AM
dmanlyr's Avatar
dmanlyr
dmanlyr is offline
I agree, as shown, the photo shows a HOT air intake.... a definate step back from the power increasing STOCK cold air intake system!
Of course I imagine that it made more noise, and more noise always means more horsepower... right?
David
Old 04-29-2011, 09:46 AM
lew52's Avatar
lew52
lew52 is offline
More air , more HP.....
Old 04-29-2011, 09:52 AM
snowdog79's Avatar
snowdog79
snowdog79 is offline
I'd skip the "cold" air intake if I were you, air intake is not what is holding the 300/6 back. And like others have mentioned, adding K&Ns like pictured above actually hurts performance by letting in hot air from under the hood. It's pretty tough to get much more out of a later, FI 300, Ford didn't leave much power to be had without major expense. That motor is all about torque, not high RPM horsepower.
Old 04-29-2011, 10:11 AM
lew52's Avatar
lew52
lew52 is offline
I agree that the air intake system on an I 6 may not help much with that low rpm motor , but on the higher reving V/8s you can pick up as much as 15 HP depending on the motor....Lew
Old 04-29-2011, 01:35 PM
thechief66's Avatar
thechief66
thechief66 is offline
I made an intake duct for mine that goes from the left lower grille opening down to the stock air duct in the core support. Not only is it cold air, but it's ram air!
Old 04-29-2011, 01:42 PM
ryito1122334455
I'd love to see pics of that if you could!!!!!
I'm just trying to get the most out of my motor,
I'd like to get rid of the terrible factory air box,
And I heard if you "open up" the air and the exhaust
You get better performance....whatever that means.. I know the basics of mechanics......my skill level 3 outta 10. Lol. Tuneups and oilchanges and stereos
Old 05-01-2011, 02:20 PM
skyfox10's Avatar
skyfox10
skyfox10 is offline
Hey Lew, I agree here, but I've also heard that you can gain about 1% hp increase for a 10°F cooler intake charge...
So if you get anough air to gain 10HP (a 5% gain), and end up with a 50°F warmer intake, then your results are canceled out. While you break even in HP, you still are loosing torque (and mpg) in the low end due to the heat.
I've used 2 different K&N Setups. One that had no heat shield (pictured above), and another with a heat shield. I notices no gains with the non shielded kit, but I did seem to notice a performance gain with a shielded kit.
Granted, all testing is very subjective, but that's just what I noticed.
Quick Reply: how to make a cold air intake??
