Ford 351m/400 and 429.460 bell housing depth - Ford Truck Enthusiasts Forums
Old 04-26-2011, 01:56 AM
401477534 401477534 is offline
401477534 is starting off with a positive reputation.
I have been told that the depth of the bell housings on the 351m/400 is different then the 429/460. 351m/400 housings are easier to come by and i was wondering if one would bolt up to a 460, i know the pattern is the same but is the depth the same?(4 speed manual transmission.)
Old 04-29-2011, 08:52 PM
Chiefrider007 Chiefrider007 is offline
Chiefrider007 is starting off with a positive reputation.
I'm getting ready to do just that, use a 400 bellhousing on a 460. On my first attempt I found there is a depth difference, took it all back apart, and left it for a couple of years due to other projects. Since I have found that you can use spacers and make it work but I do not have any measurments made or materials selected. I need to mate them back up and see how much space there is first. I'm open to ideas and suggestions if anyone already has this info...
Old 04-29-2011, 10:15 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
You should use a scattershield. That 500 horse motor, think you'll ever tear up or blow up a clutch? How fast does it rev, over 5500?
That potmetal 400 bell is just going to end up imbeded in your legs if something goes wrong.
Just a thought....
Still think a C6 is the better way to go....
Old 04-30-2011, 10:27 PM
Just a thought....
I dont think I will find my self getting over 4500 rpm. The engine is only going to be in there for about another 9 months, then it getting a cummins swap. The c6 is shot in it will be well over $800 to get a good performance transmission built. And i can do a manual swap ford $400-$450, I just want to be able to drive it around a little longer.
Old 05-08-2011, 01:37 AM
Quote:
I looked quite a bit for info on spacing the bell housings..have not found any. If you figure it out tell me...if I find anymore info I will tell you.
Old 05-08-2011, 01:47 AM
Bolt your flywheel up get everything ready. Use clutch alignment tool bolt up pursue plate. Slide trans in till it bottoms out. Space left between block and bell housing added to a small amount is your measurement.
Old 05-08-2011, 01:51 AM
The small amount. I would slide the trans into the bushing in the flywheel and see if it bottoms out before doing the clutch. I haven't checked the books but would bet it only goes in so far.
Old 05-08-2011, 12:06 PM
I guess thats about the only way to do it...probably the hard way, But if I cant find a 460 bell then that would be the way to go. Sliding the transmission in all the way, I would imagine back it out a 1/16 or 1/8 of an inch so the surface or tip of the shaft wouldn't ride on anything...then add that to the thickness of the spacer plate.
Old 05-08-2011, 12:38 PM
That may be in a book or limited by the pilot bearing
Old 05-08-2011, 02:38 PM
Well, when we get to that point we will figure it out...I will go to my local salvage yard sometime this month and see if I can find a 460 bell from a truck or van, its not like a bell housing is a hot ticket item, when ever i go there the last usable parts in the truck that has been there a long time is the trans and bell.
Old 05-08-2011, 02:44 PM
Hardest to get
Old 05-08-2011, 08:24 PM
Some vans had 460 and a 4 speed, still hard to find...i found a truck with a 460 and a 4 speed, its not in the salvage yard yet, I will see what i can get sometime this month...I might end up building the c6, it will cost around $1500 to handle my engine...I dont know yet.
Old 05-08-2011, 09:22 PM
Usually old f350 dually larger in the 70's
Old 09-10-2011, 11:25 AM
jon73 jon73 is offline
jon73 is starting off with a positive reputation.
bell housing switch
There is a spacer you can buy to allow the use of a 351m and a 400 bell housing on the 460 and 429 block it is sold by six states clutch in salt lake city
Old 09-10-2011, 11:33 AM
cast numbers
I have a e1ta7505-aa bell housing does anyone know if it is for the 460 block or is it for the 351m and 400 block?
429/460 manifolds gharris54 1973 - 1979 F-100 & Larger F-Series Trucks 18 08-28-2013 03:08 PM
337? big job 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 07-26-2013 05:35 AM
427 460 bell housings jon73 1973 - 1979 F-100 & Larger F-Series Trucks 0 09-10-2011 12:23 PM
Ford 460 flywheel 401477534 Clutch, Transmission, Differential, Axle & Transfer Case 4 04-30-2011 10:30 PM
429/460 Air Conditioning Brackets? JimYoung Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 1 08-03-2003 02:39 AM
Tags
1986, 351, 351m, 351m400, 400, 427, bell, bellhousing, ford, housing, interghanable, manual, sohc, trans, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
