1968 f100 360 with hard start and stalling issues - Ford Truck Enthusiasts Forums
Old 04-25-2011, 11:05 PM
chromeLuxx chromeLuxx is offline
chromeLuxx is starting off with a positive reputation.
I have a 1968 f100 with the stock origional 360 that has developed hard starting, poor running and immediate stalling issues directly upon picking it up from a transmission shop after they replaced a leaking pan gasket, only a few monthes after they rebuilt tranny. As I tried to drive away it was very hard to start and stalled before I made it out of the lot. According to the Manager it acted in the same manner since they received the truck, even though I drove to the shop just fine. I asked him why they never mentioned it when calling me nor when I pick the truck up to no avail.
The truck does sit off and on, but always starts and runs great. The carb appears to get gas and the inline filter looks clear. I replaced the plugs, plug wires, cap, rotor, and coil (the old one was leaking oil badly upon pulling the wire). It does have a Pertronix Ignitor II electronic ignition and I'm wondering if it was affected when the coil went bad. I'm running out of ideas and it's hard to test if I can't get it running to check for spark and etc. Any ideas would be great! I've included a YouTube video URL of my truck:
<!-- m -->http://www.youtube.com/user/kehoahawaii ... WpvQNJlxXU<!-- m -->
Old 04-25-2011, 11:27 PM
87 ford f150-4x4 87 ford f150-4x4 is offline
87 ford f150-4x4 is starting off with a positive reputation.
Maybe the fuel pump?
Old 04-26-2011, 01:51 AM
crazed87bronco's Avatar
crazed87bronco crazed87bronco is offline
crazed87bronco is gaining momentum as a positive member of FTE.
Maybe they bumped the distributor or loosened some wires when doing the transmission are you sure no problems like this has happened before you got it back from the shop? it possibly could be worn timing chain or gearing but I don't think this would be your problem if it ran good until after you got it back
Old 04-26-2011, 06:47 AM
tmcalavy tmcalavy is offline
tmcalavy is gaining momentum as a positive member of FTE.
Check and reset the timing, pull and check the fuel pump, look in the fuel pump hole with a light and inspect the timing chain and gears. If the timing gears/chain are stock original, good time for replacement. Afterwards, put a vacuum gauge on the engine and adjust the carb after it has been cleaned and the timing reset. Might also run some Sea Foam through your crankcase and fuel system...did that to my 69 F250 with 360/C6 yesterday and it blew a lot of smoke...but now runs like a striped ape. I doubt the tranny service had anything to do with your problem...probably just coincidental...unless they monkeyed with the engine.
Old 04-26-2011, 10:22 AM
Mike G Mike G is offline
Mike G is starting off with a positive reputation.
If the shop just replaced a pan gasket, there is nothing there that would have caused any problems. I would check into the carb, see if the choke was affected in any way. Since you do not drive it much, there may be internal carb issues as well. When you replaced the plugs, did you open them up to Pertronix specs? Also, you can put the points back in to see if that works.
Old 04-26-2011, 10:34 AM
merlynr's Avatar
merlynr merlynr is offline
merlynr is gaining momentum as a positive member of FTE.
What about the vacuum line running to the auto tranny. Maybe they knocked it off.
Old 05-06-2012, 07:17 PM
Sounds like it has a ignition problem
Old 05-07-2012, 08:55 AM
MIKES 68 F100's Avatar
MIKES 68 F100 MIKES 68 F100 is offline
MIKES 68 F100 has a good reputation on FTE.MIKES 68 F100 has a good reputation on FTE.MIKES 68 F100 has a good reputation on FTE.
Quote:
+1 Probably left the vacuum line off or it is cracked .
Old 05-07-2012, 10:10 AM
rustywheel68 rustywheel68 is offline
rustywheel68 is starting off with a positive reputation.
check your wires- maybe the ground strap from the block to the firewall?
i took mine in for a transmission rebuild about 1.5 years ago. they were VERY sloppy putting it back in, and left my trigger wire to the mini-starter up against the exhaust manifold.
it was burned halfway through before i even got the car home.
any ideas appreciated thanks miller56 1973 - 1979 F-100 & Larger F-Series Trucks 2 03-08-2016 05:55 PM
Idle dips with very light throttle daddylee100 1987 - 1996 F150 & Larger F-Series Trucks 2 12-30-2014 04:18 PM
1995 E350 7.3 DI turbo turbo, no power, stalls at normal operating temp asemastermech 1994.5 - 1997 7.3L Power Stroke Diesel 175 12-11-2013 12:08 PM
backfiring, running rich 68f10059 1967 - 1972 F-100 & Larger F-Series Trucks 34 10-15-2013 11:06 AM
93 F150 4.9L Miss Fire/Stumble When Warm m_menosky 1987 - 1996 F150 & Larger F-Series Trucks 2 11-29-2009 09:21 AM
Tags
360, 69, choke, f100, f250, ford, fuel, hard, manual, pump, start, starting, time, truck, youtube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
