indexing an engine for distributer
Second, remove the #1 cylinder sparkplug.
Third, have someone bump the ignition switch while you have a finger over the #1 cylinder plug hole. When you feel compression and the TDC mark is lined up with the timing indicator on the block, your then at TOP Dead Center on the compression stroke.
Fourth, position the distributor with the vacuum canister facing straight forward and the rotor button between the the 1 o'clock and 2 o'clock position.
It make take several attemps to drop the distributor in place. It will rotate in a counter clockwise direction, but when it drops correctly the rotor button should be facing the #1 firing position.
I hope this helps a little.
I'm a little confused, how did you set the timing at 8 deg BTDC without getting the engine to run?. Anyway, loosen the hold-down bolt and try turning the distributor small increments at a time while someone is trying the to start. Good luck.
Success
It was 180 out. Set it right, fired right up, and runs perfect. My son was so happy to have his truck back. I also put a new alternator, voltage reg, cap, rotor, plugs, and wires on it. So it runs better then when he bought it. Thanks for all your help and tips. I cant say enough about this forum. Hopefully I will be able to return the favor.
Torklift Sheryl
Vendor Specials, Discounts, Product Announcements & Group Buys
04-27-2017 05:45 PM
Torklift Sheryl
03-23-2017 05:54 PM
Torklift Sheryl
02-17-2017 01:08 PM
Torklift Sheryl
12-19-2016 03:26 PM
Torklift Sheryl
08-19-2015 01:44 PM
