Got my Reese Sidewinder
Wow, received my Sidewinder today, should have eaten my Wheaties today took all I had to put the boxes in the truck. Going to need some help to install. Figure I can put it in the hitch to build then jack it up to connect to the 5er. Anybody have any experience and can give me some pointers?
No this is a replacement hitch box that moves the swtivel point back 22" so you get almost 90 degrees. I have s slider hitch that binds when I need it so this is the next step. The swivel point on the hitch is wedged and the swivel point is moved to under the hitch pin instead.
YouTube - Reese Sidewinder Shortbed Towing Solution.wmv
George: I got the 5th air borne sidewinder and installed on my Monty. So far I love it tracks and backs better than the standard pin box. The air bag allows it to just float, nice ride. Dont try and install without help. I had two friends to help. Raised the front up with the jacks. Had a bench with the pin box on it and then lowered the front. A couple of drif pins or spud bar to put in the holes and align for bolts help also. Pm me for more info. bastech
bastech
Thanks for the offer, I may need to take you up on that. Won't be installing it till it gets warmer, maybe a little later in May. I saw an installation video with two guys holding the hitch box up while another put the bolts in. Huuum I guess I'll have to think about who would be dumb enough to help..... Can't wait to see how it works on my truck.
Thanks again
http://www.youtube.com/watch?v=APKM9GHRDGU
Thanks again
George,
Looks like a pretty straight forward installation. I can't figure out why they needed to grease the bottom or the top of the wedge? A couple of tapered punches stuck in either side of the new pin box is a quick way to align the bolt holes on both sides and take some of the weight during the installation. I did that when I had to raise my pin box because of the rear height difference between the old F250 and the new F350. Good luck with the installation. We need pictures.
-Gavin
-Gavin
George,
-Gavin
-Gavin
I would assume the weight on the hitch itself would stay the same. I will have to ask Reese. One of the first places I will go when I can tow is the scales, lot of info there.
Gotta admit it has been fun doing the research on these hitches and options. Just don't tell my wife how much money it will cost us! So, probably sounding like an idiot because I am still learning, is there a reason you opted for a sidewinder over a slider? Do sliders have a history of being problematic?
My slider was fine the first three years. It began to refuse to slide after that. I pulled the hitch out and the slides worked fine. I cleaned and lubed the rails and put the hitch back in the truck, the hitch slid like butter. Get to Florida and tried to slide to maneuvering position and no dice. Set the 5er up and after I unhitched I checked the hitch and it slid ok.....
Sam
The guys that put my hitch in this truck did it right. Very few will put the fifth bolt in the rails, my installers not only put the fifth bolts in they had some bolts and put six bolts in each rail. I also purchased the brackets made for my truck, instead of the universal set. The custom brackets were not a set of four 2 or 3" angle brackets. these brackets went from the front of the front rail to the rear of the rear rail with a notch to go around box rail. The installers were impressed they had only pet the universal brackets prior to my install. I don;t think I have anything to worry about.
you are moving 2,000lbs about 3 ft.. and it all rests on that pin box.. the hitch platform top will rotate forward & back , but the hitch box on the trailer can't move.. so the frame right there is taking a heck of a (unexpected) beating. was straight up/down.. now its a twisting force
Sam
