'95 5.0 towing cam
on
There are a few cams that would swap in and not upset the computer but it's mostly a waste of time, add 1.7 rockers to the stock cam and longtube headers and you'll have about as much low end power as a 5.0 will produce... which still won't be enough to turn those giant meats with any authority.. you need 4.88 gears.
I haven't looked under it to see what gears it's running, but i'd imagine no lower than 4.10s. I just bought this Bronco from a dealer, it wasn't jacked up to mudbog, but instead to look pretty, but i intend to give it purpose. The truck is fair offroad, for a truck with stock gears & an NP435 swapped into it. It doesn't pull very strong running down the road, that's my main problem. I want to run this thing down the highway like i've done with other large 4x4s, but this thing is having none of it.
I bought the truck from a dealer a few weeks ago, they were asking $3,500, but the came down to $1,400. They (and i) believed the motor was knocking, and it would barely run. I drove it 20 miles home about 50mph, running like crap. I intended to stick it in the mud and run it until it broke, then swap something big into it, but after i got home and put a fresh battery on it, the thing ran smooth except for the knocking. I revved the engine and noticed the knocking stopped while revved. The knocking ended up being the exhaust rattling against the frame. Now the damn thing runs absolutely perfect (except for idler pulley chirping), too good to drop out of it.... dangit.
Why would you want to run anything but the proper gear ratio for that size tire? you are making the motor work way to hard to try and turn those meats. if you dont want to upgrade gears then drop down to 33's at minimum. your motor will thank you for it as would your axles. 36" tires are about max on the bronco's halfton diffs just so you know. unless its going to be a pavement queen of course.
on
Ford Axle Code Chart .: Articles
TheTowingCowboy
11-08-2011 08:25 PM
pipman76
11-25-2009 08:09 AM
choochoof150
11-26-2007 09:55 PM
