largest tire size on '93 F150 4X4 - Ford Truck Enthusiasts Forums
Brakes, Steering, Suspension, Tires, & Wheels Click Here
Old 03-20-2003, 09:46 PM
bjolie bjolie is offline
bjolie is starting off with a positive reputation.
Question largest tire size on '93 F150 4X4
I just picked up a 1993 F150 4X4 for a steal ($300.00!) and although the truck runs and drives great, those 235 15's just look tiny! How large a tire can I put under this thing without needing any lift under the truck?
Also, If anyone has pics of what they recommend that would be super!
Any help is appreciated, thanks a bunch!!
Brian.
(93 F150 4X4, 4.9L 180k Mi)
(98 Ranger 4X4, 3.0L 106k Mi)
Old 03-20-2003, 10:02 PM
MustangGT221's Avatar
MustangGT221 MustangGT221 is offline
MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.
That would be a 32/11.5/15 comfortably. Pics of that setup are in my gallery.
Old 03-24-2003, 10:30 PM
Zinfinity Zinfinity is offline
Zinfinity is starting off with a positive reputation.
MustangGT: You can get 32's on your stock rig with no rubbing? i have 31's and i didn't know i'd be able to go higher, its nice to hear!!
Old 03-24-2003, 10:54 PM
You can if you get aftermarket wheels with the right backspacing. I have them on the stock Eddie Bauer wheels, it rubs on the radius arm but, it's really not a problem because you're not suppose to turn the wheel against the steering stops anyway.
Old 06-28-2003, 05:28 PM
brt brt is offline
brt is starting off with a positive reputation.
I noticed in your gallery photos that your old red truck had front springs that were not black. Were they an aftermarket set that lifted the front end at all?
'92 F-150 4WD (with ONLY 36,000 miles)
'92 Ranger 4WD
'94 Explorer 4WD
'92 Jeep Wrangler (I have to have some non-Ford in the driveway!)
Old 06-28-2003, 10:59 PM
Yup, that truck was lifted 4". The aftermarket parts list is listed there. Lucky...I almost didn't catch this.
Old 07-04-2003, 12:59 AM
1994ford 1994ford is offline
1994ford is starting off with a positive reputation.
I've got 31x10,50 on my 94 and they fit good with plenty of suspension movement. rubs on my right radius arm a bit but it's not a real big deal.
Some questions for a new owner. 85F350IDI 1987 - 1996 F150 & Larger F-Series Trucks 12 01-08-2015 04:05 PM
Intermittent Cruise Control Issue 93 F150 imacitybilly 1987 - 1996 F150 & Larger F-Series Trucks 5 09-03-2014 04:27 PM
2000 CCSB 4x4 7.3L bullet proof suggestions? Punisher29073 1999 - 2003 7.3L Power Stroke Diesel 26 09-25-2012 12:00 PM
Sloppy Steering 89 F150 4X4 Terross 1987 - 1996 F150 & Larger F-Series Trucks 3 08-19-2004 10:24 AM
'92 F-150 Nite Edition HP rating? Taz79 Nite, Nascar & Other Limited Edition Ford Trucks 6 01-24-2002 05:32 AM
Tags
1993, 4x4, f150, largest, stock, tires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
