HELP! F450 TAIL AND BRAKE LIGHTS NOT WORKING
Old 04-25-2011, 12:53 PM
Bill Conner's Avatar
Bill Conner
Bill Conner is offline
Trailering
Question HELP! F450 TAIL AND BRAKE LIGHTS NOT WORKING
This is very strange, all of a sudden the tail and brake lights stopped working also the turn signals are doing the fast blinking thing. I have checked every fuse in the truck from under the dash to under the hood, I have looked at all the wiring under the body and the trailer wiring. The turn signals are very dim in the rear and the emergency flashers do work but are also very dim. I did notice that one time when I turned the lightrs on the right rear tail light came on very dim but as soon as I turned on the ignition the tail light went out. Has anyone had a similar condition ? could it be a problem with a multi switch? ANY help would be greatly appreciated. Thank You, Bill
Old 04-25-2011, 01:37 PM
itsjustdan26's Avatar
itsjustdan26
itsjustdan26 is offline
Bump. At first I thought it was maybe just a few bulbs. Its not uncommon for them both to blow at the same time, but with the dimming of the lights, it sounds like a wiring issue.. Have you tried to swap the bulbs with new?
Old 04-25-2011, 02:09 PM
Bill Conner
Trailering
Hi, yes I switched the bulbs first with each other and then with new ones, and got the same results.
Old 04-25-2011, 02:15 PM
onelionhunter's Avatar
onelionhunter
onelionhunter is offline
Are these your truck lights that are dim, or your trailer lights? If it is the trailer, I would suspect a bad ground.
Old 04-25-2011, 02:25 PM
SpringerPop's Avatar
SpringerPop
SpringerPop is offline
Even if it's the truck lights, check your grounds.
They're just as important as the hot leads to make the bulbs light up.
And easily forgotten.....
Pop
Old 04-30-2011, 10:07 PM
MotorheadRQ's Avatar
MotorheadRQ
MotorheadRQ is offline
I can't remember the details but we had a 2003 7.3 F450 with an aftermarket bed and every so often we would lose the tail lights. Come to find out there is some relay mounted above or near the steering column that would go bad. Replace the relay and everything went back to working. Thats not to say there was not a ground problem on the bed that we could not find, but the relay fixed it for awhile.
Good luck.
Old 04-30-2011, 10:56 PM
88f1504x4's Avatar
88f1504x4
88f1504x4 is offline
Powerstroke Doctor
I would be suspectecting the multifuntion switch. I have seen them do some weird things.
rworld
05-31-2020 07:00 PM
steve2z
05-15-2019 07:09 AM
BlueOx460
03-25-2017 10:31 PM
38Chevy454
1983 - 2012 Ranger & B-Series
10-27-2016 10:27 AM
72Blazerod
03-11-2016 09:26 PM
Quick Reply: HELP! F450 TAIL AND BRAKE LIGHTS NOT WORKING
