Condenser swap, possible? - Page 2 - Ford Truck Enthusiasts Forums
Old 04-26-2011, 02:55 PM
Josed87 Josed87 is offline
Josed87 is starting off with a positive reputation.
Like by where the hose connects to the compressor there should be a fitting to screw in a high side pressure switch, if you did get a hose for a 94 f150. At least thats whats the pictures show on the advance website.
Oh okay, sounds simple enough. I'm gonna have them to do the opposite. Have them cut the part off my 92 hose and put it on the 94 hose so it can be a barrier hose.
Old 04-26-2011, 03:10 PM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
The high pressure switch is located on the manifold assembly that attaches to the back of the compressor:
Look at location A4. It may have to be plugged if you do not installed a high pressure cutoff switch. I am not sure if it has a schrader type valve in that port to prevent it from leaking to the atmosphere.
Old 04-26-2011, 03:21 PM
jas88's Avatar
jas88 jas88 is offline
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
OK, the reason I don't have one is that I have since converted my truck from the 300 Six it had when I originally did the R134a conversion to a 460 now. When I swapped in the 460, that is when I added the 94 condensor.
With regards to the manifold, the 300 manifold would not fit so I used the 460 manifold and mated it to the 300 (barrier) hoses just using regular hose clamps. I think the 300 manifold had the switch already in place, I just did not wire it in.
Old 04-27-2011, 02:42 PM
Ahhhh okay it all makes sense now. So how much freon did you put in once done? Does a 91 r134 conversion, take them samebas a factory 94 r134 system? And you wouldnt happen to havent a pic of them new condenser from them front of the truck would you? Want to make sure I get the right type haha
Not too cool, yet?? Jonnys.1991 1987 - 1996 F150 & Larger F-Series Trucks 0 09-08-2015 10:37 AM
A/C condenser retrofit shaker666 1973 - 1979 F-100 & Larger F-Series Trucks 0 03-18-2015 07:47 PM
Suggestions for A/C Refit? kc5hwb 1973 - 1979 F-100 & Larger F-Series Trucks 4 11-03-2011 02:54 PM
Another r134a conversion question Josed87 1987 - 1996 F150 & Larger F-Series Trucks 14 06-30-2011 11:15 PM
Replacing AC condenser blueford 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 05-29-2006 08:54 PM
Tags
1991, 75l, 92, 94for, 97, ac, condenser, f150, f250, fittings, low, port, pressure, swap, truck, v6, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
