bronco gas tank conversion
hello, I have a 1992 F150 supercab shortbed 2WD truck. Im currently rebuilding this truck and have it pretty much torn down almost all the way, and now I am starting to get parts for it to begin putting it back together. I saw a thread on here about the 33 gallon bronco gas tank conversion and I understand it is possible to do, but I have a couple questions im hoping someone can answer.
1st. My truck is 2WD, most of the trucks i have seen the conversion on are 4WD. is height going to be a major issue here?
2nd. My truck was a fleetside and i have a flareside bed to put on it now, kinda the same as above but will the clearance between the bed and the frame be an issue?
3rd. I know there is a 25 gallon tank also, if height is an issue, would it work to install the 25 gallon tank instead?
sorry for all the questions, but these are some things I have been looking for an answer to and I dont want to buy something that i wont be able to use due to height to ground or bed clearance. thanks!
thanks for the reference atleast, i wasnt trying to say i didnt appreciate it lol, i was just thinking that maybe with it being lowered it might sit up a little higher off the ground as well as having the skid plate on it, im not to sure about doing this conversion now though, because even without my truck being lowered it might still sit pretty low to the ground...
i only had to because the bed was off when doing so and i had set up the bottom straps tighter which pushed the top of the tank up higher than the original location. (if that makes sense)
