Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > 6.2L V8
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8 SPONSORED BY:
  #1 (permalink)
Old 04-24-2011, 10:46 PM
iggy2's Avatar
iggy2 iggy2 is offline
Garage is empty, add now
iggy2 is starting off with a positive reputation.
Driveshaft one piece or ?
I was under my truck today and noticed that I have a 3 piece drive shaft with a small center section that it attached by 2 supports. The small center section is covered with a rubber boot.
I see others with 4x4 have a one piece driveshaft.
I have the SC, LB, 2x4.
__________________
2011 F250 6.2L
2012 Georgetown Motorhome Ford F-53 Chassis with V-10 (22,000lb chassis)
  #2 (permalink)
Old 04-25-2011, 08:31 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Not sure about the newer trucks, but the regular-cab and the supercab/shortbed had one-piece driveshafts in the earlier Superdutys. Everything else had the hanger bearing - which is what that "support" is that you see.
The 4x4's you saw, were they regular cab, or supercab-shortbed?
__________________
- art k. - Moderator for the Superduty, V10, 6.2L and FE forums
'13 Taurus SHO 3.5L Ecoboost w/Perf Pkg
'01 F250SD SC SB XLT V10 4x4 Volant CAI Hedman headers 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see. ®
  #3 (permalink)
Old 04-25-2011, 07:15 PM
butch50 butch50 is offline
butch50 is starting off with a positive reputation.
Also commonly called a carrier bearing and it is very common in long wheel base trucks. The ones you were seeing with a one piece shaft where most likely SB or shorter wheel base trucks.
  #4 (permalink)
Old 04-25-2011, 07:40 PM
My Skilz My Skilz is offline
My Skilz is starting off with a positive reputation.
Strange i have a 4x4 CC short bed with a 1 piece ,,,,,
  #5 (permalink)
Old 05-01-2011, 02:02 PM
Super08's Avatar
Super08 Super08 is offline
2011 Ford F-350
Super08 is a splendid one to beholdSuper08 is a splendid one to beholdSuper08 is a splendid one to beholdSuper08 is a splendid one to beholdSuper08 is a splendid one to beholdSuper08 is a splendid one to beholdSuper08 is a splendid one to behold
It should be a two piece unless you have a 2011 and they have just changed them. All crewcabs since 1998 have had two piece shafts.
__________________
2012 Ram 3500 Laramie DRW
gone but not forgotten...2011 F350 CC SB Lariat 6.2 4WD 4.30's
  #6 (permalink)
Old 05-01-2011, 02:58 PM
Scrming's Avatar
Scrming Scrming is offline
2011 Ford F-250
Scrming is starting off with a positive reputation.
From when I was at Corsa... mine is a 4x4 (guess I better update my sig!)
Click the image to open in full size.
__________________
2011 F-250 Crew SB 6.2 - 3.73s - XLT - 4x4 - Tuxedo Black Metallic
Airaid Intake - dB Performance Exhaust - BFG All Terrains - Pioneer 3200BT - Alpine F300 - Shiny Stuff...
My blog thing.. The Super Duty
  #7 (permalink)
Old 05-01-2011, 10:13 PM
Super08's Avatar
2011 Ford F-350
Cool they have changed for 2011, aluminum to boot. I am impressed. This hopefully should help solve some of the driveshaft issues with load height changes.
__________________
  #8 (permalink)
Old 05-08-2011, 07:20 AM
iggy2's Avatar
Here is a shot of my drive shaft.
__________________
2011 F250 6.2L
  #9 (permalink)
Old 05-08-2011, 10:02 PM
Super08's Avatar
2011 Ford F-350
That is how all of my crewcabs have been including the one I have now. If the other guy has a one piece is it a mid year change, or did he buy it aftermarket and is just having fun with us?
__________________
  #10 (permalink)
Old 05-09-2011, 04:31 AM
Scrming's Avatar
2011 Ford F-250
Quote:
Nope... that's the way it came... I bought my 2011 in January... no idea when it was actually built...
__________________
  #11 (permalink)
Old 05-09-2011, 06:30 AM
Super08's Avatar
2011 Ford F-350
It has to be a mid year change then. I'll see what mine is when I get it.
__________________
  #12 (permalink)
Old 05-09-2011, 07:57 AM
iggy2's Avatar
My truck was built March 2011 with the mid shaft support.
Now the question is why they did it and/or is it better or worse than a single shaft?
What is the advantage?
I guess the shaft can take more torque and will have less wabble?
__________________
2011 F250 6.2L
  #13 (permalink)
Old 05-09-2011, 08:19 AM
Scrming's Avatar
2011 Ford F-250
Just checked. My truck was built January 2011.
  #14 (permalink)
Old 05-09-2011, 08:35 AM
Krewat's Avatar
There's really no advantage to either one. OK, maybe the single-piece is easier to work on And, you never have to change the hanger bearing.
The issue is whether or not they can get the angle the same at the tranny and at the rear-end. The front and back "pinion" angle has to be the same, otherwise it'll vibrate. U-joints when operating at an angle do not spin at a constant speed. The angle determines the acceleration/deceleration the driveshaft goes through, and if both angles are the same, that change in speed is canceled out.
Also, on very long wheelbases, the two-piece helps ground clearance. But I think that's a non-issue on these trucks anyway, the exhaust and gas tank are usually lower than the driveshaft anyway
__________________
  #15 (permalink)
Old 05-10-2011, 09:37 AM
Byram's Avatar
Byram Byram is offline
Byram is gaining momentum as a positive member of FTE.Byram is gaining momentum as a positive member of FTE.
Mines a May -2010 build & has the 2 piece/ carrier bearing like iggy posted - Its a Super cab/ long box...
__________________
2011 F-250SC XLT
6.2; 3.73 EL; 4x4; BFG M/T 285's; B&W Turnover; Ranch Hand; Oasis XD 4000 OBA & Aux Battery; 5 Star assisted!
"Peace is that brief glorious moment in history when everybody stands around reloading".
Tags
2011, conversion, drive, driveline, driveshaft, duty, f250, ford, peice, pice, pickup, piece, shaft, super, superduty
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
