T Meyer Rotating assembly - Ford Truck Enthusiasts Forums
Old 04-24-2011, 11:26 PM
Casey429's Avatar
Casey429 Casey429 is offline
Casey429 is starting off with a positive reputation.
Hey everyone. I'm looking at building a healthy, steetable 400 for my '77 F-250. I've gotten the block hot tanked, line honed and bored .030 over. I've been kicking around the idea of getting the Tim Meyer balanced rotating assembly. I was just curious if anyone was using one of these, or at least some of the parts and what you think of them. Thanks!
Old 04-25-2011, 04:47 PM
POPAJON POPAJON is online now
POPAJON has much to be proud ofPOPAJON has much to be proud ofPOPAJON has much to be proud ofPOPAJON has much to be proud ofPOPAJON has much to be proud ofPOPAJON has much to be proud ofPOPAJON has much to be proud ofPOPAJON has much to be proud ofPOPAJON has much to be proud ofPOPAJON has much to be proud of
Tim is a great guy to get to know. I've gotten his flat top pistons and a lot of info from him. IMO go for it. Just follow his recommendations and you can't go wrong. John
Old 04-25-2011, 04:56 PM
smokeyb97's Avatar
smokeyb97 smokeyb97 is offline
smokeyb97 is starting off with a positive reputation.
Quote:
I'm using his engine kit and pistons in my 351M/408 and I'm really pleased with the parts. I'm using a 400 crank from him also, but I'm using my original rods.
Just a suggestion, if you're going to use a flat tappet cam I would recommend using Tim's inspected lifters. I'm speaking from experience, the quality control for flat tappet lifters is lacking. After having to pull the intake and replace brand new lifters because of leak-down issues that resulted in valve-train ticking, you'll be glad you went with his new inspected lifters, BELIEVE ME! Tim goes the extra mile to have each lifter checked before sending out.
Old 04-26-2011, 12:38 AM
Casey429's Avatar
Thanks for the input, guys. I'm looking at getting the whole deal just because my crank needs work (polished, maybe even possibly cut .010 under), and I like the idea that its balanced. The engine I bought also came with an Edelbrock Performer 400 intake. And yes, I will be going with a flat tappet cam, possibly this unit from Comp:
COMP Cams K32-221-3 - COMP Cams High Energy Cam and Lifter Kits - Overview - SummitRacing.com
Being that lifter quality seems to be lacking, I'm going to definitley look into the inspected ones. I'll probably still get the K-kit just to get the valvesprings, locks and retainers. Smokeyb97, might I ask you what cam are you running? Also, what kind of rocker arms? Any other valvetrain modifactions?
Old 04-26-2011, 01:28 AM
smokeyb97's Avatar
I'm running the CompCam 255DEH, Scorpion roller rockers #1024 and oem valves, springs and retainers.
Help! H2O in fuel? Icthus in AK 6.7L Power Stroke Diesel 21 01-12-2017 04:47 PM
05 F250 vs Meyer EZ Classic Plow System Stevekron1 Excursion - King of SUVs 3 09-08-2015 11:26 PM
'05 F250 vs Meyer EZ Classic Plow Mount System Stevekron1 1999 to 2016 Super Duty 2 09-08-2015 06:37 AM
Lightweight homeplow snow plow goldsmje Excursion - King of SUVs 10 12-21-2011 09:34 AM
Fluid for Meyers plow? Ford_Six General Automotive Discussion 2 10-27-2009 08:00 AM
Tags
289, 400, assemblies, assembly, balanced, duratec, ford, horsepower, lifters, lightning, meyer, pistons, rotating, tim, tmeyer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
