10 DTC's; what do the codes mean? - Ford Truck Enthusiasts Forums
Old 04-24-2011, 07:54 PM
wildbonz wildbonz is offline
wildbonz is starting off with a positive reputation.
Hi. This is a follow up to this thread;
http://www.ford-trucks.com/forums/10...-stranded.html
2006 F250 6.0 Crew 4x4 110000miles
Truck was running fine. Suddenly wrench light comes on. Then the check engine light. Truck will only idle at about 750rpm. Shuts off on its own after a few minutes. I scanned it and got 10 codes. Can someone please make sense of them and tell me what is actually wrong. ETC, IPR, VGT, VREF?????
Here are the codes. Can someone decode this for me please? Thanks.
P0107 MAP/BP Sensor Circuit Low Input
P0405 EGR A circuit low
P0472 Exhaust Pressure Sensor Low
P2104 TAC System - Forced Idle
P2122 Throttle/Pdl Position Sensor Switch 'D' Circuit Low
P2127 Throttle/Pdl Position Sensor Switch 'E' Circuit Low
P2132 TP/APP Sensor/Switch F Circuit Low
P2138 Throttle/Pdl Position Sensor/Switch 'D/E' Corelation
P2139 TP/APP Sensor/Switch D/F Voltage Correlation
P2285 ICP Sensor Circuit Low
Old 04-24-2011, 08:27 PM
bismic's Avatar
bismic bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
Are you sure battery voltage is good?
Old 04-24-2011, 08:35 PM
I'm pretty sure it is. I replaced both batteries a few months ago. There were no indications of low voltage.
Old 04-24-2011, 08:40 PM
David Chamberlain posted this in the prior thread;
dchamberlain
Garage is empty, add now Join Date: Sep 2007
MAP, EGR, EBP, APP and ICP sensors all giving codes. Each one of those sensors rely on VREF (conditioned, regulated +5V from the PCM).
I'd bet that you have a shorted VREF wire somewhere. How to test that and find it, I haven't a clue. One of the smart techs will have to help you with that.
__________________
David Chamberlain
2004 F-250 SD, 4x4 FX4, 6.0L PSD
Oregon Chapter Member: To join the Oregon Chapter, click HERE
Old 04-24-2011, 08:50 PM
bismic's Avatar
Inspect each sensor's connector.
Google up "6.0L bible". It willl show you where the sensors are.
Old 04-25-2011, 10:44 AM
Once I find the sensors what exactly should I do from there?
If I don't see anything obvious and I clean them off, what next?
How do I test the sensors to see if they are working?
I need to get this thing back up and running but I'm kinda lost as where to go from here.
Old 04-25-2011, 11:48 AM
brickie's Avatar
brickie brickie is offline
brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.
Six of the ten are throttle related,I would check the wiring on the throttle position sensor first thing.
Old 04-25-2011, 01:40 PM
I can't find an obvious wiring problem.
When checking the fuses though, the entire right side of the cab fuse box wasn't getting power. I was checking the fuses with a test light instead of pulling each one, and the whole left side lit up, but the right side fuses had no power to them. I'm pretty sure that most of them used to light up when I checked them.
The fuses under the hood wouldn't light up either.
EDIT: Actually I remembered they should work with key on, and they do, except for four on the far right middle.
Old 04-25-2011, 01:41 PM
Bismic, that 6.0 Bible has a ton of great info. I couldn't find where the actual sensors were in it though.
Old 04-25-2011, 01:43 PM
In the 6.0 Bible, it says I should check a FICM Logic Fuse / Logic power fuse. I can't find it. The picture shows it to be in a small separate fuse box with a few other relays.
Is this for a different year truck?
Old 04-25-2011, 01:50 PM
Also, in the DTC code analysis, it says the problem for most of my codes could be a short somewhere, as David Chamberlain said earlier.
It says there is a 'Pinpoint S for 12 way conn. diagnostics'. It says there is a main 12 way wiring harness/connection that delivers power and ground to all of the sensors. The pinpoint test will help find the cause I assume.
For the; P0107- pinpoint test H
P0405 pinpoint W
P0472 pinpoint X
P2285 pinpoint Q
the rest pinpoint AG
I don't know how to do these. I have access to a high quality scanner, a Snapon Mobis Elite, can it do these pinpoint tests?
It looks like I may have to go to a dealership.
Old 04-25-2011, 02:28 PM
m-chan68's Avatar
m-chan68 m-chan68 is offline
m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.
Hmmmm. If I were the servicing tech that this problem child had landed on my doorstep, I would likely 'attack' the six DTCs highlighted in bold red first, before addressing the other four you've listed. Just glancing through the Ford PC/ED for DTC P2104 it lists APP Sensor, Signal circuit shorted as possible causes, and for DTCs P2122, P2127 and P2132 it lists APP Sensor, connections, open in signal circuit, signal circuit shorted to ground, and lastly for DTCs P2138 and P2139 it lists difference in sensor readings. All of the six DTCs direct you to pinpoint test 'AG' in the PC/ED. If you are equipped with a scan tool that can monitor live data, access APP #1, APP #2 and APP #3 (both % and volts). Do a full sweep of the accelerator pedal. Do all readings increase and decrease in the same proportion, consistent with movement of the pedal? If not, check the wiring to the accelerator pedal itself to check for obvious issues and repair as needed.
Then it's time to attack P0107, P0405, P0472 and P2285. But that's for another thread.
Old 04-25-2011, 09:59 PM
I hooked it up and here is what I found;
APP % 0
. no thr. 1/2. full
APP 1 v 0.91 0.45 0.13
APP 2 v 0.34 0.65 0.91
APP 3 v 0.22 0.53 0.79
APP_Low v 0.00
EBP v 0.05
ECT v 3.31 (no fault)
FICMLPWR v 11.5
Ficmmpwr v 48.0
ficm sync no
ficmvpwr v 11.5
IAT V 3.21
IAT 2 V 3.94
ICP V 0.04
MAF V 0.04 no fault
MAP FAULT - NO
MAP kpm 28
sync no
TPCT V 0.00
EBP V 0.05
EGR FAULT NO
EGRVP V 0.16
EGRTP V 0
VREF 3.50
VFC FAULT NO
VGT FAULT NO
WFS NO
TBC FAULT when I tried to start it
I'm not sure what it all means. Any help would be appreciated.
Old 04-25-2011, 10:07 PM
bismic's Avatar
VRef should be 5v.
Did you locate the TPS D,E,F sensors? If so, did you inspect the connector and wires?
Old 04-25-2011, 10:13 PM
m-chan68's Avatar
APP % 0
. no thr. 1/2. full
APP_Low v 0.00
EBP v 0.05
FICMLPWR v 11.5
Ficmmpwr v 48.0
ficm sync no
ficmvpwr v 11.5
IAT V 3.21
IAT 2 V 3.94
ICP V 0.04
MAF V 0.04 no fault
MAP FAULT - NO
MAP kpm 28
sync no
TPCT V 0.00
EBP V 0.05
EGR FAULT NO
EGRVP V 0.16
EGRTP V 0
VREF 3.50
VFC FAULT NO
VGT FAULT NO
WFS NO
V-Ref should indicate 5.0 volts if I'm not mistaken. Somehow or other there is a V-Ref short somewhere, causing a low V-Ref voltage. Your APP readings are way off as well, according to the PC/ED reference values listed. APP #1 should read between 0.7 to 4.2 volts, APP #2 should read between 1.4 to 4.1 volts and APP #3 should read between 0.8 to 3.5 volts.
What does the wiring to the accelerator pedal look like? Is it all chewed up or completely intact?
08 trouble codes DieselDenny 6.4L Power Stroke Diesel 0 01-31-2017 08:51 AM
Starts, no throttle, need help with codes 5280 2007 - 2014 Expedition & Navigator 0 12-28-2016 05:17 PM
5.4 Revving issue and im stumped. F250Oldie 1999 to 2016 Super Duty 0 07-15-2016 09:17 PM
6.7 DTC (Diagnostic Trouble Codes) Sgt93 6.7L Power Stroke Diesel 9 06-21-2012 11:47 PM
p2138 trouble code help agteacher 1999 to 2016 Super Duty 19 08-28-2011 12:46 AM
Tags
2004, 401, 60, accelerator, carolina, code, codes, dts, ford, north, obdii, p2127, pedal, powerstroke, radio, readings, voltage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
