obd port, where'd it go? - Ford Truck Enthusiasts Forums
Old 04-24-2011, 06:36 PM
liljohn liljohn is offline
liljohn is starting off with a positive reputation.
ok, this time this truck has me stumped. 97 f250 4x4, 460 ci. . check engine lite came on, broke out the trusty code reader and can't find the obd port. looked under drivers side dash, nope, all I could find was an eec port under the hood on drivers side fenderwell. the reader's connector won't fit. anyone care to enlighten me. dealer says it's under dash but 15 mins. of looking got me nothing but a headache. thanxs
Old 04-24-2011, 06:40 PM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
It is the one you found, eec port under the hood on drivers side fender.
You have an OBD-I truck and you will not have any port inside.
Old 04-24-2011, 06:42 PM
MSKnudson's Avatar
MSKnudson MSKnudson is offline
MSKnudson is starting off with a positive reputation.
Mine is on passagers side by the left knee just under the dash board but that's on a '96
Old 04-24-2011, 06:44 PM
subford's Avatar
Quote:
But you have an OBD-II truck and his is a OBD-I truck.
Old 04-24-2011, 06:53 PM
ostrx250 ostrx250 is offline
ostrx250 is starting off with a positive reputation.
all vehicles are suppose to be obd2 after 95 but that didnt happen to all somehow if you have the eec then thats what you have i'll bet
Old 04-24-2011, 07:18 PM
subford's Avatar
Quote:
Not true.
All 1997 5.8L/7.5L (49 States Or Super Duty) and not sold in California were OBD-I trucks.
Old 04-24-2011, 07:21 PM
danger-ranger93's Avatar
danger-ranger93 danger-ranger93 is offline
danger-ranger93 is starting off with a positive reputation.
If it has EEC it won't have a OBD II port inside...
Old 04-24-2011, 07:26 PM
subford's Avatar
Quote:
Not true.
OBD II trucks are still EEC, I think you mean EEC-IV.
OBD II trucks are EEC-V.
EEC: Electronic Engine Control.
EEC-V: Ford's fifth generation EEC system.
Old 04-24-2011, 07:35 PM
Thanxs guys. I guess thats what threw me. I assumed that year would have it inside. Is there an adapter made to fit between my obd II reader and the eec? And while Iam online what is the purpose for the vaccum tube and canister filter coming off the H shaped fixture in my intake tubes going to the intake manifold. These would be answered if I could find a shop manual. BTW, this a great forum, glad I found it.
Old 04-24-2011, 07:43 PM
Conanski's Avatar
Conanski Conanski is online now
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
OBD-2 scanners are often of no use with OBD-1 vehicles so you're probably gonna need to get an OBD-1 code reader(Equus 3145) or flash the codes on the check engine light. The second method is pretty easy to setup, put a jumper between the STI and Sig_Rtn lines in the EEC test connector, turn the key to run and the codes will begin flashing out.
Old 04-24-2011, 07:44 PM
subford's Avatar
That depends on the MFG of your scanner.
But you can get a scanner to read your codes for about $30.00 at most auto parts stores.
Here is a good one:
Old 04-24-2011, 07:56 PM
subford's Avatar
Can you tell me where (cross coordinates) in the below diagram the vacuum part you are talking about:
Old 04-24-2011, 09:41 PM
looks like C5 is pretty close . IAC valve maybe ? no wires, looks like 1/2 or 3/4 hose from intake to filter to plastic piece inline with intake tubes from airfilter to throttle body. When it's unplugged from intake tube device(?) it pulls some serious vaccum!
Old 04-24-2011, 09:49 PM
subford's Avatar
Do you see something that looks like it in this photo?
Old 04-24-2011, 11:00 PM
The hose and filter are below the intake hoses where they connect to the throttle body. You can't see them in this photo.
OBD1 location a 1995 f250 with the 7.3 Powerstroke diesel Collision 1994.5 - 1997 7.3L Power Stroke Diesel 18 02-12-2016 08:09 PM
OBD11 port location tangster 1999 to 2016 Super Duty 2 06-27-2015 02:55 PM
Where's the obd1 port?? 1990 ranger 2002exPSD Ranger & B-Series 2 08-19-2011 11:50 PM
96' F-150 has OBD-II connector wired for OBD-I? FlatlanderKW 1987 - 1996 F150 & Larger F-Series Trucks 2 08-04-2010 05:18 PM
1995 f-250 obd port? f-250 yooper 1987 - 1996 F150 & Larger F-Series Trucks 3 03-03-2009 03:03 PM
Tags
06, 1997, 2004, 87, chasis, diagnostic, expedition, f150, f250, f53, ford, located, obd, plug, port
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
