sound/heat insulation install
Old 04-24-2011, 09:16 AM
learpilot's Avatar
learpilot
learpilot is offline
What are people using to install the sound/heat insulation inside the cab? Or does it come with a glue. Do you use contact cement? Thanks for your help
Old 04-24-2011, 09:58 AM
F250racer's Avatar
F250racer
F250racer is offline
Depends on your budget. I'm planning to use something called "quick roof", from home depot. Basically it's thick rubber on one side and foil on the other. I'm going to cover everything with then then probably use either carpet insulation or duct insulation over that.
From what I've heard it's very similar to dynamat just way cheaper.
Some sites will tell you to use something called "peel and seel", from Lowes, it's similar to quick roof but makes your truck smell like asphalt when it heats up.
Old 04-24-2011, 10:32 AM
Moe Craig's Avatar
Moe Craig
Moe Craig is offline
It depends on what product your using... If your buy a insuation material that is designed to go in a vehicle as Insulation, there are spay in and also peel and stick versions... Or as stated above you can make your own... I will probably use Dynamat, but I would like to do Lizard Skin then Dynamat...
Old 04-24-2011, 10:42 AM
CharlieLed's Avatar
CharlieLed
CharlieLed is online now
Spray-on LizardSkin or similar home recipe thermal insulation paint followed by Dynamat...no glue necessary with these products.
Old 04-24-2011, 11:16 AM
arrowheadfred's Avatar
arrowheadfred
arrowheadfred is offline
lmc
LMC has the best price on insulation and its cut to fit.
Old 04-24-2011, 12:24 PM
f1barry's Avatar
f1barry
f1barry is offline
I used a self stick foil faced fiberglass that I cut to fit. It did a great job on cutting down the noise as well as thermal insulation. I haven't covered it yet but it doesn't look bad. May have been from LMC and was reasonablely priced.
Old 04-24-2011, 04:13 PM
raerjim's Avatar
raerjim
raerjim is offline
I see where Eastwood is now marketing a peel and stick heat/sound insulation similar to Dynamat but considerably cheaper. No matter where you get it, quality product is expensive.
Old 04-24-2011, 05:06 PM
BACAGrizz's Avatar
BACAGrizz
BACAGrizz is offline
I used some self adhering stuff from a company called 'soundproof cow'. It's sound and heat insulation combined in one product like Dyna-mat with foil on one side. It's been fairly easy to install so far with a rubber roller. The product is called 'RoadBlockR'.
Last edited by BACAGrizz; 04-24-2011 at 08:54 PM. Reason: correcting company name.
Old 04-24-2011, 07:42 PM
HD74's Avatar
HD74
HD74 is offline
This is what I used and have been very satisfied with heat and sound.
https://www.ford-trucks.com/forums/7...d-upgrade.html
Old 04-24-2011, 11:37 PM
dalmeida's Avatar
dalmeida
dalmeida is offline
I was looking at the pre-cut insulation sold by Mid-Fifty. Is anyone familiar with these products? How do theirs and LMC's stack up to dynamat + dynaliner or some heat insulation product? I'm not inclined to use a lizard skin type product because I'm not prepared to purchase the spray equipment nor skilled enough to use it nor would I have enough further use needed to justify the expense.
351Cleveland C4
10-06-2016 09:32 PM
Sehome
10-01-2016 01:34 PM
GeeeMCeee
12-07-2015 07:41 PM
Tom-N
Vendor Specials, Discounts, Product Announcements & Group Buys
10-13-2015 03:59 AM
hobbs53
61
06-14-2015 12:52 PM
Quick Reply: sound/heat insulation install
