sound/heat insulation install - Ford Truck Enthusiasts Forums
Old 04-24-2011, 10:16 AM
learpilot learpilot is offline
learpilot is starting off with a positive reputation.
What are people using to install the sound/heat insulation inside the cab? Or does it come with a glue. Do you use contact cement? Thanks for your help
Old 04-24-2011, 10:58 AM
F250racer's Avatar
F250racer F250racer is offline
F250racer is starting off with a positive reputation.
Depends on your budget. I'm planning to use something called "quick roof", from home depot. Basically it's thick rubber on one side and foil on the other. I'm going to cover everything with then then probably use either carpet insulation or duct insulation over that.
From what I've heard it's very similar to dynamat just way cheaper.
Some sites will tell you to use something called "peel and seel", from Lowes, it's similar to quick roof but makes your truck smell like asphalt when it heats up.
Old 04-24-2011, 11:32 AM
Moe Craig's Avatar
Moe Craig Moe Craig is online now
Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.
Quote:
It depends on what product your using... If your buy a insuation material that is designed to go in a vehicle as Insulation, there are spay in and also peel and stick versions... Or as stated above you can make your own... I will probably use Dynamat, but I would like to do Lizard Skin then Dynamat...
Old 04-24-2011, 11:42 AM
CharlieLed's Avatar
CharlieLed CharlieLed is online now
CharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud of
Spray-on LizardSkin or similar home recipe thermal insulation paint followed by Dynamat...no glue necessary with these products.
Old 04-24-2011, 12:16 PM
arrowheadfred's Avatar
arrowheadfred arrowheadfred is offline
arrowheadfred has a good reputation on FTE.arrowheadfred has a good reputation on FTE.
lmc
LMC has the best price on insulation and its cut to fit.
Old 04-24-2011, 01:24 PM
f1barry f1barry is offline
f1barry is starting off with a positive reputation.
I used a self stick foil faced fiberglass that I cut to fit. It did a great job on cutting down the noise as well as thermal insulation. I haven't covered it yet but it doesn't look bad. May have been from LMC and was reasonablely priced.
Old 04-24-2011, 05:13 PM
raerjim's Avatar
raerjim raerjim is offline
raerjim is gaining momentum as a positive member of FTE.
I see where Eastwood is now marketing a peel and stick heat/sound insulation similar to Dynamat but considerably cheaper. No matter where you get it, quality product is expensive.
Old 04-24-2011, 06:06 PM
BACAGrizz's Avatar
BACAGrizz BACAGrizz is offline
BACAGrizz has a good reputation on FTE.BACAGrizz has a good reputation on FTE.
I used some self adhering stuff from a company called 'soundproof cow'. It's sound and heat insulation combined in one product like Dyna-mat with foil on one side. It's been fairly easy to install so far with a rubber roller. The product is called 'RoadBlockR'.
Last edited by BACAGrizz; 04-24-2011 at 09:54 PM. Reason: correcting company name.
Old 04-24-2011, 08:42 PM
HD74's Avatar
HD74 HD74 is offline
HD74 is gaining momentum as a positive member of FTE.
This is what I used and have been very satisfied with heat and sound.
http://www.ford-trucks.com/forums/79...d-upgrade.html
Old 04-25-2011, 12:37 AM
dalmeida's Avatar
dalmeida dalmeida is offline
dalmeida is starting off with a positive reputation.
Quote:
I was looking at the pre-cut insulation sold by Mid-Fifty. Is anyone familiar with these products? How do theirs and LMC's stack up to dynamat + dynaliner or some heat insulation product? I'm not inclined to use a lizard skin type product because I'm not prepared to purchase the spray equipment nor skilled enough to use it nor would I have enough further use needed to justify the expense.
Glue for Hood and Firewall insulation Sehome 1973 - 1979 F-100 & Larger F-Series Trucks 0 10-01-2016 02:34 PM
First drive today GeeeMCeee 1957 - 1960 F100 & Larger F-Series Trucks 14 12-07-2015 08:41 PM
sound insulation hobbs53 1948 - 1956 F1, F100 & Larger F-Series Trucks 61 06-14-2015 01:52 PM
Advice for inside of doors Redgranite_Yooper 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 06-05-2014 06:19 PM
Did Broncos ever come with hood liners? ErrorS 1978 - 1996 Big Bronco 17 06-22-2012 11:23 PM
Tags
1940, auto, automotive, diesel, engine, f250, foil, ford, forum, heat, install, insulation, peel, price, sound, stick, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
