The 3rd 1966 project for me
#46
Good evening all. This is the largest post I've ever made anywhere.
Please excuse this but we're trying to document everything for our upcoming Warrant in Debt proceedings. This has very little to do with complaining and everything to do with trying to set the correct tone with the issues. Also, there are several pics that didn't make the post since they're hard to make out given the angle or close-up. All told, this is the worst screw-over I've ever experienced. This even trumps being terminated while on vacation by certified letter.
We did get the truck back around Feb 4th but it's been he!! ever since. 17 months this turkey had the vehicle and all the while did nothing but lie about what was being accomplished. I admit I always had my doubts and when I did visit to see things, I was snowed by the show and the fact I couldn't get under the truck to see things. I took the guy at his word because the people who referred me all had some terrific work accomplished. 22 months, two shops run by idiots and this is what we end up with. It can't be driven with the column, speedo and wiring issues plus the brakes don't work. The cover for it arrived today so now it will sit until we can save enough funds....again! It's gonna be a while since the daughter is about to start looking at colleges next year and she stand to get accepted at several we couldn't even dream of affording. I'd use the equity in the truck but that's what we did to afford doing the work that didn't get done! This really sucks since the car I'm driving right now was going to be hers but it won't have the 20,000 miles we planned. Because of no truck, it's at 51,000 and 24 months to go before she leaves for school.
bed patch and cross member support not installed properly
bed patch again
Hole remaining in bed on left side front
top-side of patch rusting through thin as paper bed coating
old brake line never removed and he even hoisted the engine (supposedly) when he panted it
same
cab bushings not replaced
rust not removed
missing screws
missing bolts and misaligned mount
wiring never replaced
locks left unattached
more missing or loose bolts
trim not installed properly
same
door skins that were provided were not installed<br/>drivers door
same
same but weather stripping is also not installed correctly
sander scratches on glass?!?!
missing engine mount bolts
other side of engine
more missing bolts
can you say rust on the new paint again! Actually the metal is split and the paint is chipping. That's just 4 weeks in the weather 20 additional areas of rust on the paint
passenger door skin not used. decided to use fiberglass patch and that's not even done right
same door
beautiful work
another missing bolt
more missing bolts
can you say great job on the floor patch?
more great welding pics
look at the precision
and seamless style. Check out the rust on the bottom center of the pic too
I'm sick now
more rust
note the great frame repair for the core support mounts
ditto
stupendous job repairing the nut that stripped out of cowl/fire wall
more weather stripping and missing bolt issues
who needs door locks anyhow
great job installing the lower pillar for the drivers door
missing bolt, this is getting old
and we have another missing bolt
fender well support brackets on core support missing
ditto
look at that great fit and finish
more missing bolts
there were new cab corners installed on the other side why this wasn't fixed the world may never know
more rust on the cab corners
who needs a rear end gasket when you have gasket seal!
no wonder the doors don't close properly
drip gutter was seam sealed but he forgot to smooth it
ditto.
had a new window track but somehow the old one went back in?
they have products to clean-up this nowadays reight
partly why the doors don't close
more of the same
it never rains in Virginia on the Coastal Plains. the passenger will have a clear view but too bad the wiring wasn't fixed. wiper doesn't work because of that.
missing column clamp. can anyone say impale the driver in a wreck?
Looks do not say it all. Taken from a distance it looks great but once up close.......not!
bed patch again
same
rust not removed
missing screws
same
same
more missing bolts
same door
beautiful work
more missing bolts
I'm sick now
more rust
ditto
ditto
more missing bolts
ditto.
more of the same
builttodrive
22
03-13-2018 04:24 PM
mosigndude
59
06-25-2017 12:19 AM
albany23
02-07-2017 01:46 PM
Nose is
01-10-2016 07:19 PM
