The camper thread! Pulling, using, equipment, maintenance!
#811
#812
Just to be contrary, I take my batteries out and store them in the basement and just occasionally charge them. I have also in the past left a battery installed and occasionally plugged it in.
I have hopes but hardly any evidence my golf cart batteries might last longer with the warm storage. Makes me feel better anyway.
#813
I don't think there is a water heater bypass. I did check and there is antireeze in the hot water heater. Mine has the AF tube near the pump with a valve, I sucked the fluid into the system, the cold side was filled, I opened the hot valves to drain the water back. The toilet has AF in the tube and I dumped some in the black and some down the grey drains.
What kind of adapter do you all use to blow out the lines?
Here is a thread from RV.net that includes a few pics to help ID the different styles of water heater by-passes. RV.Net Open Roads Forum: Travel Trailers: removed bypass valve. now no hot water?
#815
I was just thinking, I have 2 batteries in the boat and never take them out, mainly because it's a PITA. So far so good on them holding up. Camper batteries are easy to take in the house. I guess that all adds up to lazy. I do have a cutoff switch on all of them, keeps them from draining via parasitic loads.
#816
Humm..... None of those look like mine. It was late and with it getting dark so early it was hard to see. On the outside I only see the gas lines and power to the water heater. Under the sink I only see the kitchen sink plumbing. I will dig down to the pump and take a look.
#817
Yeah, the by-pass should be inside a cabinet by the backside of the water heater. My current TT has the valves hidden by an easily removed false side wall in the under sink cabinet, old toyhauler was a similar setup.
Good luck!
#820
finally camping
It's 30* outside and my family and I are comfortable inside our trailer that we finally got to take out. Bought our Ex about 4-5 months ago, it was out of commission for a month while I found a HPO leak, then bought a TT about a month ago. Picked it up last weekend and finally made it out for this weekend, set up in the dark, forgot silverware, using my hitch for a tire chock, and water in park has been turned off for the winter even though the Web said that wouldn't happen until middle of a December, but I'm pretty sure we are having fun.
2014 Forest River Surveyor Cadet 32' bunkhouse with outdoor kitchen. Bought used and saved $10,000 off sticker.
#821
Sounds like you are having more fun than me, I'm stuck at work and my TT is bundled up in it's cocoon in the driveway till Spring.
But you know we have rules here, Pics or it didn't happen!
#822
Going out to check on my TT in a little bit. Has about 6 inches of snow on it!
Big Green Ex I felt your pain the last time we were out in our TT! Park said water would be on till the 2nd weekend in November. We were in the park the 1st weekend of November. Maintenance guys shut the water off 45 minutes before we went to dump tanks and flush out for the year! I was a little upset!
So after dumping the tanks and getting back to the house, I devised a plan to wash tanks out! Set the trailer up in the driveway. Got 2 5 gallon buckets. Hooked up the discharge hose and water hose from the house. Boys did a bucket brigade to the toilet in the house with the buckets!
We ran water through the sinks and toilet and emptied the tanks into the 5 gallon buckets until nothing but clear "clean" water was flowing nicely. I then winterized the camper. I never knew I needed 6 gallons of rv antifreeze to do a 33' camper!
BTW you are having fun! This is just the first of many LEARNING trips!
#825
