The camper thread! Pulling, using, equipment, maintenance!
  #736
Old 08-26-2014, 11:14 PM
Restlesswildman's Avatar
Restlesswildman
Restlesswildman is offline
So I watched my trans temperature while towing this weekend. The highest I saw was 190. Without the TT and "NORMAL" driving, I only see an average of 160ish. Are these normal temps for the tranny?
  #737
Old 08-26-2014, 11:22 PM
william_04_x's Avatar
william_04_x
william_04_x is offline
190° while towing is fine for a TS trans. I see temps over 220° while towing steep and heavy here in the desert SW.
I say it a lot, but the TS trans really is a remarkable piece of equipment. With proper maintenance, it'll treat you good for a long time, even if you don't treat it the best.
  #738
Old 08-26-2014, 11:28 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
How heavy were you towing? What were you towing? What was the outside temp? Was it on flat ground or up a grade?
Stewart
  #739
Old 08-27-2014, 12:30 AM
Bently_Coop's Avatar
Bently_Coop
Bently_Coop is offline
Got my IR thermometer in. Neat little gadget. Hopefully get to mess around with it tommorow and learn all the functions.
  #740
Old 08-27-2014, 09:37 PM
Restlesswildman
Stewart
7500 lbs 92 f up and down hills.. nothing huge....
  #741
Old 08-27-2014, 09:41 PM
william_04_x
Under those conditions, I wouldn't worry about those trans temps a bit, Wild Man.
  #742
Old 08-28-2014, 12:11 AM
Stewart_H's Avatar
Stewart_H
^^^^ what he said.
100 over ambient isn't anything to worry about with that weight of a travel-trailer.
Stewart
  #743
Old 08-28-2014, 08:39 AM
Snowseeker's Avatar
Snowseeker
Snowseeker is offline
After installation I have yet to see my trans go over 180f. Mark (former ford trans engineer) mentions that up to 220-230 is ok.
  #744
Old 08-28-2014, 10:57 AM
pgguru's Avatar
pgguru
pgguru is offline
is that for the transmission in a 6.0 or is a 7.3 the same?
  #745
Old 08-28-2014, 06:24 PM
Snowseeker's Avatar
Snowseeker
He only commented for the 4r100 transmissions usually. But I am sure it is the same for pretty much any vehicle auto transmission.
  #746
Old 08-28-2014, 06:33 PM
william_04_x
With regards to the TS trans, I thought I read something in the past about sustained 250°, and 300° for 30 minutes.
  #747
Old 09-07-2014, 08:08 AM
Excurvelle's Avatar
Excurvelle
Excurvelle is offline
The RV lifestyle is most enjoyable if you let the wife pick out the ammenities she wants. Us fellas just like towing the stuff around, hooking up, and having a nice place for her to cook while we watch TV.
I have an +11K#, 27' toy hauler that I've dragged around with my 2WD X for over 100K miles. Keep the dry weight under 9000#, which will leave you with room to add a ton of extra stuff, and you'll do fine. I've pulled coast to coast, and over plenty of passes with 10% grade or more.
My tongue weight is very close to 1500#. I have 1400# spring bars on my WD hitch, and I run my rear air bags at 60psi.
Weigh your truck. GCVWR should be 20K#. Deduct loaded(passengers,gear,fuel) truck weight from that, and you'll have max recommended trailer weight.
We went to a camping show yesterday, my wife likes a heavier more expensive unit and I like a not as expensive lighter unit. The one I like is a GVWR of 9490 with a dry weight of 7155 and a 788 dry tongue weight. The one she likes is a GVWR of 10663 with a dry weight of 8130 and a 1155 dry tongue weight.
I have a 24' car hauler that I rarely use with a Propride hitch I plan on transferring it over to the new coach. I do not have air bags or different springs so I may need to modify. What do you guys think?
  #748
Old 09-14-2014, 08:14 AM
Excurvelle's Avatar
Excurvelle
Well we did it, we pick up our new 30' Puma on Saturday, with the salesman's help we kept the weight in the low 7000 range and the wife got everything she wanted except for the outside kitchen.
  #749
Old 09-14-2014, 09:04 AM
hav24wheel's Avatar
hav24wheel
hav24wheel is offline
You won't miss that out door kitchen anyways. The fridge out there has to be plugged into work anyways.
  #750
Old 09-14-2014, 02:07 PM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
I need to winterize mine, shes not going on any more adventures this year.
Quick Reply: The camper thread! Pulling, using, equipment, maintenance!
