Which Ford Engine am I?
11-23-2016, 07:43 PM
I liked the Hemmings writer's assessment that the power level was akin to that of the era's Mopar 318.
Kind of a slug, given the weight.
Pop
05-24-2018, 07:41 PM
05-27-2018, 10:03 AM
One is a trick question: The blue one above isn't a Ford at all. Duramax.
The other one is a Six-Oh!, which is getting the much-needed studs.
Pop
05-27-2018, 11:48 AM
I am really surprised how some of you can tell an engine just by one look of the short block.
Jim
05-27-2018, 12:30 PM
Granted I’m devious
, but I thought the top pic was 7.3l. Bottom is the 6.0l
Indeed, Pop is good.
05-27-2018, 06:28 PM
I've rebuilt a few over the years.
I was hanging around an automotive machine shop when I was fourteen.
7.3 isn't cross-bolted, and the oil pump isn't on the side of the block, nor are the oil galleries down the side.
The above photo IS a 7.3, as evidenced by the "windows" on the cam gear.
Pop
07-10-2018, 09:02 PM
Neither Ford:
12.3l
12 rotors! Sorry, had to remove the engine accoutrement
07-14-2018, 12:27 PM
A one-off originating in Muskegon, Michigan, for a project in Dubai.
They certainly have the bucks to run with a project like this.
Pop
07-14-2018, 09:11 PM
Heck, might as well make it camless for $1 million more.
Duke looks interesting too.
07-15-2018, 09:19 AM
I guess if Felix Wankel could solve the combustion chamber sealing problem, I suspect that the folks at Duke can do that, too.
But that engine looks to be a huge "head gasket" leak in-the-making.
Pop
08-21-2018, 08:48 PM
Beep beep.
08-22-2018, 09:32 AM
Looks like a 32-valve 5.0.
Sweet motor!
That pallet's worth some real bux!
Pop
08-22-2018, 07:45 PM
Got it! Anytime they require EFI compatible fuel delivery system with a minimum pressure of 75 gph @ 60 PSI....
the price goes up.
08-23-2018, 02:13 AM
Should work fine in my Thunderbird. LOL
Jim
08-30-2018, 09:16 AM
Quote:
Originally Posted by
Nighteyez
They make a real nice powerplant for early-iron street rods instead of the traditional Mouse Motor.
And yes, you gotta' supply them with fuel!
Pop
